Hey all,
I am planning a system I'm going to make in about a week. I am going to have crossovers and everything outboard so its ok if the crossover and amp and everything aren't all planned out. I want to pair 2 line arrays I'm making with 2 more tweeter line arrays to help with combing issues. I plan on using a 3in tang band full ranger I for the main arrays (6 drivers each, I know its hardly an array) and then the Apex Jr tweeter spaced a bit over 1in, probably 18 of them for each tower. I am going to cross it over around 4500 Hz because thats when the combing will start being a problem. I've been looking into crossover and amp options and I want something flexible and adjustable and I've come across something I think is pretty promising for both of these criteria. I like not needing a passive crossover which can be very expensive and difficult to do well, biamping has a ton of benefits also, and I could do some rough eq adjustment to compensate for room conditions. One of these: Pyle Pro PYX3X 3 Way Active Stereo Crossover Network 248-4708 And two of these (one for midrange L + R, one for HF L + R) Lepai Tripath TA2020 Class-T Hi-Fi Audio Amp w/Power Supply 310-300 I would also have an active subwoofer for the lows. Heres the 3in driver Tang Band W3-881SI 3" Speaker 299-113 What do you guys think about this setup? Could I wire my Mac directly to the crossover as an input? Last edited by kctess5; 18th December 2011 at 11:47 PM. Reason: spelling... |
| The Best Active Crossover - Here! | Samuel Jayaraj | Multi-Way | 33 | 13th August 2011 06:18 AM |
| Passive crossover into active crossover | hahfran | Multi-Way | 16 | 10th February 2008 06:16 PM |
| Active crossover | MaXiZ | Pass Labs | 9 | 22nd November 2003 06:04 PM |
| active crossover | aaronboumans | Analogue Source | 4 | 31st May 2003 04:59 PM |
| XVR1 active crossover, discrete active stage | promitheus | Pass Labs | 18 | 22nd July 2002 01:29 AM |
| Page generated in 0.05969 seconds (79.55% PHP - 20.45% MySQL) with 10 queries |
