Old 18th December 2011, 07:34 PM   #1
Exclamation Amplifier loud speaker and sub
Hello, i would ike to know what kind or wich loudspeaker can hi 140- 150 dB.with a wattage of at least 25 000 watts but a great thing that gives a punch in the breathing!
thanks you for your help!
Old 18th December 2011, 08:11 PM   #2
The Matterhorn is a 40-driver, 40 kW self-powered Tom Danley designed tapped horn subwoofer which can produce 105 dB of output at 250 meters, with a response -3 dB at 12 Hz.
That is about 153 dB at one meter, 123 at 31 meters.
Matterhorn
Old 18th December 2011, 09:34 PM   #3
pski is offline pski  United States
Matterhorn
You didn't mention burst organs . .
Old 19th December 2011, 12:52 AM   #4
Inductor's Avatar
JBL Dance Club Series or Marquis.
"Calculated Maximum Peak SPL: 142 dB SPL @ 1m (3.3 ft)" with only a few thousands watts.
JBL :: Product Family
Last edited by Inductor; 19th December 2011 at 01:01 AM. Reason: Note: tweeters are from Selenium
Old 19th December 2011, 01:17 AM   #5
I always asked me that : what the SPL ?
Also, i would like to put it in my house so just not a wall, something that can be carried
please
I would really like something that just not vibrate loud but that give a shot
do you understand what i talk about?( i have a little difficulty to explain cause my primary language is french, im from quebec)
Old 19th December 2011, 01:33 PM   #6
Inductor's Avatar
please
Yes, "vous parlez français, je comprend". You can use Google tools (More/Translate).
Do you want to build or to buy.
Look here for an example.
"138dB/1M maxiumum output. 150dB max output in groups of four. The 12 π is basshorn subwoofer using two 12" woofers with external heat sinks and push-pull drive."
Pi Speaker Kits, Subwoofer Kits, 12Pi basshorn flat pack kit
Pi Speaker Kits, Subwoofer Kits, 12Pi basshorn driver kit
You can use that with the RCF H1312.
RCF - H1312
Last edited by Inductor; 19th December 2011 at 01:58 PM. Reason: RCF-H1312 + 12π BasshornSUB
Old 19th December 2011, 02:20 PM   #7
mdocod is offline mdocod  United States
Send a message via AIM to mdocod
http://www.danleysoundlabs.com/pdf/J...ec%20sheet.pdf
http://www.youtube.com/watch?v=pk54IFD4znw
Old 19th December 2011, 11:09 PM   #8
Lightbulb average
but , whats the average price for this?
i search with the serial number but i'm not able to find the cost pf the JH90 loud speaker
Old 19th December 2011, 11:22 PM   #9
Default the best
the best i have found is that but i want something thats hit your breathing with the power of bass!
Atomic Loud Speakers
Old 20th December 2011, 11:52 AM   #10
Inductor's Avatar
You didn't mention price on the first place.
Do you want a sub or a speaker (like for monitoring and/or stereo)? I would go with something on the likes of the JBL 4350 (also if you want to use your drivers).
What one pair of speakers you would purchase?
http://www.jbl43.net/customerfeedback/showroom2l.jpg
First Loud Speaker Box Build Need Help!!!!! Jameslc Construction Tips 15 16th March 2011 08:22 AM
Using the loud speaker in different way!! anuk07 Multi-Way 1 30th December 2009 05:09 PM
The Loud Speaker Kit May Specials LSK Vendor's Bazaar 0 21st May 2009 01:56 AM
make your own loud speaker. and I mean it metalinspired Multi-Way 12 24th September 2005 01:10 PM
loud speaker 6 ohm resistance petros Multi-Way 1 29th December 2003 05:27 PM
Page generated in 0.11605 seconds (81.58% PHP - 18.42% MySQL) with 11 queries
