6L Sealed Enclosure - 6.5" Woofers!
Old 21st December 2011, 01:30 AM   #21
pski is offline pski  United States
I'll pick another "car audio" brand: JL Audio. Their 6W3 woofer in a small (8.5x8.5x6.25 internal) non-vented surfaced mount enclosure is incredible for about USD 100 plus the box you will need to make.
I have this in my ancient Camry wagon and everybody is amazed.
It should be an easy inclusion in a portable solution.
P
Old 21st December 2011, 04:51 AM   #22
mdocod is offline mdocod  United States
Send a message via AIM to mdocod
Hello pski,
The driver you suggested in sealed configuration, and the driver I suggested in a vented configuration will cross paths at 50hz. In other words, for equal input power, the driver I suggested plays everything above 50hz louder and more efficiently.
80.5dB@1W1M efficiency does nothing positive for this build. If we had a 300W amp to work with your suggestion would be more reasonable.
Old 21st December 2011, 12:06 PM   #23
Veloxy is offline Veloxy  Sweden
The B&C seemed nice, although it seems impossible to find it here in europe... and I guess its abit to pricey :/
Really... I still believe the ScanSpeak 18w/4434G 7" is still the best deal here... Even thou the sensitivity is 88.3 db for 1w/1m it IS still the loudest speaker I have found so far. This is due to it being a 4 ohm woofer.
I simulated all the top suitable speakers and these are the graph's I got:
Frequency
Loudness
Yellow: Monacor SPH-176 in a sealed enclosure.
Green: ScanSpeak 18w/4434 in BR
Blue: B&Q 6NDL44 in BR
Old 21st December 2011, 12:21 PM   #24
The amplifier delivers 10W in 8Ohm and 22W in 4 Ohm.
I am also later planing on using a rechargeable battery of type LifePO4, around 4200mhA which should last half a day hopefully atleast
Old 21st December 2011, 01:21 PM   #25
lduarte1973 is offline lduarte1973  Portugal
Banned
can that amp do 2 ohm ?
Old 21st December 2011, 01:33 PM   #26
No, only 4 and 8 ohm...
Old 21st December 2011, 02:11 PM   #27
Banned
cheap and noisy ?
Goldwood GW-8024 8" woofer - 4 ohm: Madisound Speaker Store
http://www.madisoundspeakerstore.com...-woofer-4-ohm/
http://www.madisoundspeakerstore.com...ar-cone-4-ohm/
Old 21st December 2011, 04:31 PM   #28
Goldwood GW-8024: Requires a sealed box with a qtc of 2.0, way to much...
Goldwood GW-6024: Requires also a sealed box. F3 of about 76Hz sounds good, better than the SPH-176 which has 80Hz. Although, a 10dB peak at 3KHz is nothing I would like to deal with :/
Hi-Vi L6-4R: F3 of about 90Hz is quite high. 88dB sensitivity is also rather low at (2.83V/1m) compared to ScanSpeak's 91.3dB.
IMO ScanSpeak still takes the lead in terms of effeciency, lineraity and quality :/
Old 21st December 2011, 04:41 PM   #29
Banned
of course it does , i own a pair of SS10F/8424G00 as mids
i just thought you wanted cheap stuff for that project
Old 21st December 2011, 05:32 PM   #30
weltersys is offline weltersys  United States
weltersys's Avatar
At about 95 dB sensitivity the Eminence Alpha 6A beats those by a good margin, but does not go quite as low.
It is a very good sounding speaker, and goes high and smooth enough that tweeter choice and crossover is easy. I have used them outdoors and could get a surprising amount of thump from them.
The box below is about the same size as your suitcase, putting a pair in the same size will still have about the same F3 (85 Hz), but will raise the upper sensitivity to 98 dB. 10 watts to each speaker should get you around 111 dB at one meter.
Art
6L Sealed Enclosure - 6.5" Woofers!Hide this!Advertise here!
6,5" to 7" midwoofer for sealed enclosure martinbls Multi-Way 93 26th September 2012 11:22 AM
Need help with 5.25" driver for sealed enclosure MrDragon1 Full Range 11 1st March 2010 12:18 AM
8" Bass driver for 6L sealed cabinet Antripodean Multi-Way 3 5th September 2009 05:41 PM
15" woofer in sealed enclosure KCCT82 Multi-Way 23 18th January 2008 03:45 PM
small, sealed enclosure using Silver Flute woofers Bose(o) Subwoofers 5 31st December 2005 05:03 PM
