BLH w/ High Xmax Driver???
Old 16th December 2011, 02:00 AM   #1
goody75 is offline goody75  United States
Default BLH w/ High Xmax Driver???
Back-Loaded Horn Question:
Is there anything wrong with using a driver that has a mid to high Xmax for a BLH design - (around 7mm / 3inches)?
What about a speaker with a mediocre sensitivity (~90 db) and higher power handling?
Old 16th December 2011, 03:52 AM   #2
AllenB is offline AllenB  Australia
When you use a driver in a horn, using a front horn as the example as this is the standard method, you place the rear of the driver into a box which you use to balance it against the pressure caused by the horn. Drivers for a back loaded horn need to be chosen carefully as you don't have this option.
This process is often referred to as 'reactance annulling' if you wanted to read up on it.
Old 18th December 2011, 02:49 PM   #3
Thanks, AllenB. I haven't gotten to it yet but I will do some reading.
Old 18th December 2011, 07:48 PM   #4
whgeiger is offline whgeiger  United States
See Rog Mogale's Design (example)
Speakerplans.com
Use the PD1850 for best results.
Precision Devices International Limited
WHG
BLH w/ High Xmax Driver???Hide this!Advertise here!
High Xmax is Great But................. OMNIFEX Multi-Way 55 2nd May 2017 10:38 PM
Woofer "Speed," high Xmax vs. low Xmax in Uframe and Sealed Enclosures jarvissound Subwoofers 35 21st March 2014 10:48 PM
What is the most durable 8" high xmax woofer? sardonx Multi-Way 14 24th July 2005 07:18 PM
12" driver with big Xmax,low Fs, & high efficiency? WolfmanX Multi-Way 18 26th November 2002 11:10 PM
Copyright ©1999-2017 diyAudio
