Hello all,
I have a pair of unloaded EV Eliminator top cabinets. I'n not sure if these cabinet are the older version that came equipped with 1/4" jacks or the newer version than came equipped with Neutrik connectors. In the event that my cabs are the older version, does anyone know if the Neutrik jackplate/crossover from the newer model Eliminator will fit into my cab? Thanks. |
#2 | |
Since your cabinets are unloaded, you need a crossover designed specifically for the drivers you plan to use, and the drivers need to be correct for the cabinet size. Fitting the jackplate is the least of your worries in an unloaded cabinet. |
#3 | |
#4 |
Does anyone know what the internal volume is for the latest iteration of the EV Eliminator top boxes?
Thanks, Theo |
| RUssian 6P14P-EV / 6n23p / 6n2p-ev / 6n8s / 6n1p / etc+ | UssrTradeCom | Vendor's Bazaar | 0 | 2nd August 2010 09:39 AM |
| Running amps unloaded | trwh | Solid State | 29 | 27th June 2008 08:48 AM |
| Unloaded LM317/337 behaviour | philpoole | Power Supplies | 20 | 12th March 2008 09:15 PM |
| 6AW6A, Unloaded | rdf | Tubes / Valves | 13 | 13th October 2006 04:39 AM |
| Page generated in 0.08255 seconds (77.14% PHP - 22.86% MySQL) with 10 queries |
