I am new to home audio and to speaker building, but I am trying to build a set of tower speakers to go with my home theater system. I would like to run a 3 way design and have been thinking about these
Dayton RS28a Tweeter Dayton Audio RS28A-4 1-1/8" Aluminum Dome Tweeter 275-130 Dayton RS225 8in Woofer Dayton Audio RS225-8 8" Reference Woofer 295-356 DIY Cable Exodus EX-Anarchy Midwoofer DIYCable.com : Intro » Home » Exodus Anarchy » Since I have little knowledge in crossover design I would like to try to use pre-built passive crossovers or an active crossover that i could tune myself. Any help you can give me in driver and crossover choice would be greatly appreciated. Building the cabinet will not be a problem, but after parts are chosen I may need help with the design of it. Tell me what you think, thanks. |
#2 |
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Your selection of drivers are kinda all over the map.Note the sensitivity of your Mid-woofer, at 84 Db your system will be a power eater. You system is only as efficient as the least efficient driver. The cool thing about towers is they are ripe for MTM arrangement , or two woofers with the tweeter placed between the two. Effectively a two-way this set-up gives you great imaging. Using two 8" drivers will be a bit of a challenge getting the frequencies to overlap effectively. PE has two-way crossovers with connections for two woofers, exactly what we're after. I would phone-up PEs' tech line as I don't know if these crossovers have impedence compensation or allow for the two woofers to venture into the 4 Ohm range when they cross.
The biggie on MTM is the De Appolito "effect", or symmetrical lobing effect. __________________________________________________ ______Rick..... |
#3 |
I can toss out the mid-woofer, it just seemed to have a good build quality and a good frequency response, I forgot to look at the sensitivity. I am not set on any of the drivers I posted above, they just looked good to me after looking at other builds online. I like the idea of a MTM with two 8's, but I was afraid of the frequency overlap like you pointed out and that is why I added the Exodus 6.5
I'm really open to any set of drivers that can give me a wide range of low distortion frequency response with good output. |
#4 |
I've already answered this by PM, why bother with PM if you want other opinions? FWIW I suggested : Daedalus as it uses two of the wanted drivers. An MTM with two 8"ers is not good with current 8" drivers, if ever. If you can't build a c/o from a parts list and diagram you should have said so, but if you wan't anything decent you will have to learn. Stay the hell away from from simple active c/o's that can't be set to do the job properly and even more away from passive off the shelf c/o's that are an utter disaster area waiting to happen. rgds, sreten. http://sites.google.com/site/undefinition/diy (see if nothing else, the excellent FAQs) http://techtalk.parts-express.com/sh...d.php?t=219617 http://www.zaphaudio.com http://www.zaphaudio.com/ZA5/ http://www.rjbaudio.com/Audiofiles/FRDtools.html http://web.archive.org/web/200909021...esigningXO.htm http://www.rjbaudio.com/ http://web.archive.org/web/200909022...ve99/Spkrbldg/ http://speakerdesignworks.com/ http://www.htguide.com/forum/showthread.php4?t=28655 http://www.deadwaxcafe.com/vzone/david/david.htm http://www.troelsgravesen.dk/Diy_Lou...r_Projects.htm http://www.humblehomemadehifi.com/download.html http://www.quarter-wave.com/ http://www.frugal-horn.com/ http://www.linkwitzlab.com/ http://www.musicanddesign.com/ Great free SPICE Emulator : http://focus.ti.com/docs/toolsw/fold...t/tina-ti.html
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 14th December 2011 at 11:09 PM. |
#5 |
just another
Hi Sreten, Blame me
Tony. |
#6 |
re: 'I've already answered this by PM...' LOL, so have I, FWIW I suggested a design nearly identical (post 3) - HTGuide Forum - Summary of key information from the 3-way WTMW / TMWW thread
re:'If you can't build a c/o from a parts list and diagram you should have said so, but if you wan't anything decent you will have to learn' - yes, but us 'old hands' take so much for granted, perhaps a link to a really simple primer on crossovers would help the OP realise it's not that hard, once some basic understanding is reached
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky Last edited by PeteMcK; 14th December 2011 at 11:39 PM. |
#7 |
Sorry for my uncertainty guys, I'm very indecisive
PeteMck sent me a link to this HTGuide Forum - Summary of key information from the 3-way WTMW / TMWW thread and I am really liking the look of that design, it seems to do everything that I am looking for and is a proven design that I can emulate and learn from I couldn't find the parts list on that build though, I must be missing it is parts-express the cheapest place to get the parts for that build? Thanks for all the replies, I appreciate it |
#8 |
My next question is what would be the best way to power them? Crown amps caught my eye
#9 | |
frugal-phile(tm)
Have a look around and see what other people are using (a large proportion will be diy) dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#10 |
re:'I couldn't find the parts list on that build though' check the zip files here: HTGuide Forum - Dayton RS WMTW Center & TMWW Mains
I had a quick squiz at the Daedelus, it only has one woofer & a more complex xover than Dennis Murphy's Dayton WWMT tower
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
| Dayton RS100-8 Tower and Center Build | skeeter99 | Full Range | 5 | 26th November 2011 12:13 AM |
| ScanSpeak ReDiscovery Tower build | pski | Construction Tips | 1 | 31st July 2011 12:41 AM |
| chip amp build for tower speakers... LM1875 vs 3886... | wankski | Chip Amps | 9 | 28th October 2010 04:53 AM |
| Curve-sided 3.5 way tower build | craigwalsh | Multi-Way | 18 | 31st March 2009 02:53 PM |
| Best tower speakers to build? $1000 | BytZ | Multi-Way | 2 | 20th July 2002 12:06 AM |
| Page generated in 0.13253 seconds (80.36% PHP - 19.64% MySQL) with 11 queries |
