i couldn`t find parameters for hpl.
are they the same speaker with h? |
#2 |
Yes they are the same driver. The HPL doesn't have the 2226 metal decal nameplate on the back. Just uses a white stencil marking.
Rob
"I could be arguing in my spare time" |
#3 |
so parameters are the same?
#4 |
HI
Over a period quite a few 2226 has been opened up by us - demagnetizing the motor and opening of top & bottom plates (for mods) , these have been noticed - 1) the magnetic flux gauss is way below the printed figure 2) there have been issues with suspension linearity to printed figures 3) some of the top plates were not tightly machined and the magnetic gap was large - leading to vc heat & compression good things 1) the cone does not tears it self out like p audio or other copies 2) the tonal quality 3) when multiple drivers are used - sound dinstinct suranjan |
#5 |
thank you all for the replies.
i found out that the hpl is in the speakers and the h is a standalone driver but they are the same. |
#6 |
Correct, one is the OEM driver without the pretty label and rubber cover arround the magnet and the other is the retail driver. I have a mixture and they measure the same as far as t/s parameters and take the same recones.
| Enclosure for JBL 2226 as a subwoofer? | pumpkin1 | Multi-Way | 7 | 15th December 2010 02:04 AM |
| Horn enclosures w/ JBL 2226 and JBL 375. | burtcheca | Swap Meet | 0 | 2nd August 2010 01:21 PM |
| Any Exp. w TH using JBL 2206 or 2226? | HK26147 | Subwoofers | 9 | 23rd August 2008 08:46 PM |
| Wtb Jbl 2226 | corkster | Swap Meet | 2 | 1st February 2008 11:24 AM |
| Keep my JBL 2226 drivers or start over | jmiyake | Multi-Way | 3 | 13th May 2002 11:23 PM |
| Page generated in 0.07353 seconds (74.23% PHP - 25.77% MySQL) with 10 queries |
