Hey guys...
In a 3-way, I'm using (because I have no choice) a 24db crossover for a 10" woofer and I can hear some phase problems when switching back and foruth between other speakers. What can I do about this? I read first order (6db) has the least amount of phasing but I cant switch, I'm stuck at 24db for all 3 drivers in each speaker due to the electronic crossover I'm using. If I get a 10" driver with a phase-plug will that help? Thanks!
My Studio |
#2 |
How do the problems sound, and what exactly is this "switching"?
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#3 |
Hi !
I don't think so. Phase plugs to my ears don't improve the phase, it is the contrary. They only improve the response. You have no choice to change the crossover point. You should have other problems but I can't tell without no more details. Cheers. |
#6 |
#7 |
There are too many variables here to isolate the crossover topology of the cause of the "phase problems".
#8 |
It's an Ashley XR2001 3/4-way Electronic crossover. The amps are Emotiva XPA-3s. So it goes signal>crossover>amps>speakers. I have another post asking if I should put Zobel networks on the drivers as well. Here's a pic of a speaker and the rack.
DIY pictures by nonsuchpro - Photobucket (larger) ![]() ![]()
My Studio Last edited by nonsuchpro; 14th December 2011 at 04:59 PM. |
#9 |
What are the other speakers you are using?
#10 |
Tweeter:
Dayton Audio PT2C-8 Planar Tweeter - Tweeters - Loudspeaker Drivers By Type - Loudspeaker Components Midrange: http://www.morelhifi.com/products/pd...et%20MDM55.pdf Woofer: Dayton Audio DA270-8 10" Aluminum Cone Woofer
My Studio |
| Help with 4th Order bandpass enclosure for a 15" 600W dual voice coil subwoofer (PA) | col | Subwoofers | 30 | 9th December 2011 04:04 AM |
| 1st order to 4th order conversion | Professor smith | Multi-Way | 22 | 28th November 2011 10:41 AM |
| My 4th order sub | hjf | Subwoofers | 2 | 17th January 2011 01:40 PM |
| 4th Order Bandpass Driver Selection | lamsv | Subwoofers | 14 | 27th May 2010 06:25 PM |
| My 1st order butterworth filter better than 4th order L-R: Why? | philipreji | Solid State | 61 | 1st March 2007 04:50 PM |
| Page generated in 0.10312 seconds (80.69% PHP - 19.31% MySQL) with 10 queries |
