I was wondering does anyone know anything about these speakers or know what they might be worth, if anything. They are a Peerless kit 3-25 from G.R.D.Instruments and cost $170 Australian at the time. One of them crackles sometimes when the volume is adjusted.
Specs are as follows: Woofer: CM 120W Mid-Range: G 50 MRC Tweeter: MT 20 HFC Crossover: 3-25 Crossover Frequency: Upper: 4000 Lower: 750 Max. Power Watts: 25 Lower Frequency Range: 40 Upper Frequency Range: 18,000 In enclosure of Litres: 100 Internal Dimensions: Height: 635 Width: 380 Depth: 412 Crossover Type: Parallel Low Pass DB-Octave: 6 Band Pass DB-Octave: 6 Band Pass DB-Octave: High Pass DB-Octave: 12 Thanks! |
#2 |
Reminds me of an old Philips I had but without seeing the back or cones it's anybody's guess.
#3 |
frugal-phile(tm)
With the DIN plug very good chance it is European. The box looks very diy, that you had a plate with that much info means that it was likly built from a kit. Philips did do that kind of thing, but the numbers don't jive, and their XOs were typical 1st order everywhere.
You'll need to pull the back off and take a pic of the insides (i would be VERY surprised if the back isn't held on with flat-blade screws). dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
That points to a problem with the volume control on your amplifier.
Shaun Onverwacht |||||||||| DON'T PANIC |||||||||| |
#5 |
It maybe a Peerless Kit 3-25 from the early seventies,which was supplied pre-wired on a baffle board.Given its age,your problem could be caused by frayed flexible leads(pigtails),especially on the woofer.
| Anyone recognise this mech? | tubenut | Digital Source | 5 | 13th March 2009 05:20 PM |
| Anyone recognise this amp? | tubewade | Tubes / Valves | 7 | 16th December 2007 10:15 PM |
| Recognise this tune? | Circlotron | Everything Else | 2 | 6th November 2007 12:29 AM |
| anyone recognise these speakers... | lt cdr data | Multi-Way | 4 | 2nd January 2006 01:48 AM |
| how does one recognise ..... | alecwek | Parts | 3 | 22nd July 2004 08:27 AM |
| Page generated in 0.08134 seconds (72.33% PHP - 27.67% MySQL) with 11 queries |
