Old 13th December 2011, 10:22 PM   #1
Default budget driver recommendations for Line Array
I'm planning on building a pair of line arrays, starting with the BFM TLAH plans. I'd like to keep the budget down, while hopefully getting a nice result (duh). I've been shopping for midwoofer and tweeter drivers, and would like to get some feedback from those who may have used some of these (successfully or unsuccessfully), or have any other suggestions I should be looking at.
Places I've checked so far - please let me know of other possible sources:
  • Parts Express
  • Madisound
  • Apex Jr.
Woofers I'm considering:
Tweeters I'm considering:
  • Peerless India T25FG-04-02 1" Silk Dome Tweeter - FR 2000-20000, fs 1942, 89 db, 4 ohm - $2.50 each
  • (BFM recommended tweeter) - $2.50 each
  • Apex Jr. cheapies (concerned they may not go low enough to crossover well) - $0.50 - $1.00 each
Design: 8 or 9 woofers + 12 tweeters per speaker; about 5' tall.
Thanks in advance for your thoughts
Old 13th December 2011, 10:55 PM   #2
Kahooli is offline Kahooli  Abu Dhabi
If you're doing fitzTLAHs, I have 4 cases of the 5.25 sony neos that were sold on PE for $.69.
How many do you want?
Old 13th December 2011, 11:00 PM   #3
mdocod is offline mdocod  United States
Send a message via AIM to mdocod
Maybe this: http://www.parts-express.com/pe/show...number=299-289
I tend to shy away from drivers with poor dampening characteristics (very high Qts, anything over 0.55 and I am generally suspect). They often sound sloppy IMO. And I think for good reason, high Qts means high impedance spike and weak motor structure, which all means less control over the cone movement, lower precision, and higher distortion.
Lots of guitar guys love those really sloppy guitar speakers with a Qts of like 1.9 or something nuts because they "color" the sound in a way that the guitar player is often looking for. When building a speaker to reproduce the already colored and recorded guitar, you don't generally want to add any more of your own color.
Old 14th December 2011, 03:20 AM   #4
Oooh, I'd take a case - or maybe two - if you're willing to part them? Thanks for the offer - I'll PM you as well in case you don't catch my post here.
Originally Posted by mdocod View Post
Maybe this: 5" Concave Paper Cone Woofer Speaker 2 Ohm 299-289
Thanks, I'll check that one out too. Bill's plan specifies ~0.5 qts, but the recommended driver is 0.69, and the Sony closeouts that reportedly work well are 0.96. I'm sure you have a point, but to my current level of understanding (speaker building books on order ), its just a number and going by what others have used.
Line Array Eq, Coldamp Driver Wa Solid State 0 11th April 2008 03:52 PM
Line Array with PHY Driver jpetek Multi-Way 5 24th February 2008 08:45 AM
Possible budget line array driver? mpmarino Multi-Way 6 7th May 2007 01:03 AM
4 driver line array using fullranges navin Full Range 33 8th August 2006 04:45 PM
Line Array / multiple driver crossover design awdtalon92 Multi-Way 2 26th March 2004 07:49 PM
Page generated in 0.09848 seconds (77.30% PHP - 22.70% MySQL) with 10 queries
