Old 12th December 2011, 02:04 AM   #1
karelch is offline karelch  Canada
Default Focal 4K2 enclosure
Hello there, this is my first post concerning a tower speaker I'm currently building. I have a Focal polykevlar kit and my question is about the mid 4'' (4K2).
Fs. 54.41 Hz
VAS 5.51 L
Qts 0.243
Qes 0.25
In a sealed box, the speaker calculator gives me a result of .74 L. driver displacement of 0.22 L. that would give me almost 1L for a speaker box. This seems really small and an odd value since the 6.5'' inch needs 55 L of space. I would like to have your thoughts on this before everything is glued and screwed together.
Note: This is my first DIY and normally I speak french so sorry if there are mistakes.
Old 12th December 2011, 03:06 AM   #2
Inductor's Avatar
Should be fine if you simulate with other Focal 4" drivers (0.6 to 1 L) and giving F3 about (or over 160Hz to) 200Hz.
Old 12th December 2011, 02:08 PM   #3
Old 12th December 2011, 02:52 PM   #4
bbggg is offline bbggg  United States
If you plan to use the driver as a true mid, ie crossed way above its resonance band, you don't really need to use T/S calculations at all. Its chamber will only serve as acoustic isolation, therefore you can design it as best as you can so as to avoid reflections and absorb stray echoes. T/S is relevant only with regard to a driver's fundamental resonance when used as a high pass filter.
High current requirement is the bane of high fidelity
Old 12th December 2011, 03:31 PM   #5
That would simplify my design.
According to T/S calculations, my 6,5'' driver should be in a ported enclosure. Is it absolutely necessary ? Could it damage the driver if it's in a sealed enclosure ?
Old 12th December 2011, 09:11 PM   #6
No, but it would probably not play as loudly in the low end of the spectrum. The software you use will probably give you some ballpark figures of LF driver displacement and power requirements under both scenarios.
Enclosure options for Focal 6m115 NcHalfrican Multi-Way 7 23rd May 2012 09:39 PM
Focal-JMlab 5W4252 5 1/4 and Hi-Vi RT1-II custom built speakers w/crossover+enclosure excetara2 Swap Meet 4 18th October 2006 06:53 PM
t-line enclosure for focal polykevlar ? please!!! scooby1 Multi-Way 2 28th June 2005 06:47 AM
Enclosure and Woofer for Focal TC120k ppmmcc Multi-Way 7 10th February 2004 11:49 AM
MTM design FOCAL 6W4311 AND FOCAL Focal TC120 Tdx2 Bas Horneman Multi-Way 1 5th February 2003 04:21 PM
Page generated in 0.08415 seconds (73.77% PHP - 26.23% MySQL) with 10 queries
