After 1 years of listener test and measurements finally the last crossover for my Monitor 3.
This new crossover have a constant impedance to match any vacuum tube and solid state without feedback so with low damping factor. the Monitor 3 There is only one cap. and I have tested this types: 1) SRC Solen MKP 2) Clarity Cap SA 3) Jantzen Z-Cap |
#2 |
I notice you have settled on a shelf where the response above 2kHz is 2 or 3dB below what's below 1kHz. I'd like to know how you came to this preference.
Also how much difference do you find there is between the Jantzen and the Clarity? |
#3 |
Most important would be the midrange for low I think the second impedance peak could give with impedance equalizer better damping behavior.
When equalized both peaks at low end, I am curious if this doesn't change the sound dramatically. So I am waiting what you will discover Andrea.
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet |
#4 |
In the listen test the Solen are much better than Clarity Cap and the Jantzen Z-Cap are a step over all.
With the new crossover the correction of the DRC is very low in the middle and high frequency band. In the near future probably I need to work with the bass reflex length (see relative plot). |
#5 |
In this last listen test has been used my new Amplifier End
Amplifier End by Andrea Ciuffoli and the my new USB-DAC http://www.audiodesignguide.com/HiRe...on_Lundahl.JPG |
| Hi-end compact loudspeakers without a budget limit | audiodesign | Multi-Way | 11 | 2nd October 2011 05:45 PM |
| Constant Voltage Impedance Measurement | Gcollier | Multi-Way | 7 | 29th June 2006 09:54 PM |
| Constant impedance relay-resistor logarithmic attenuator | x-pro | Pass Labs | 75 | 27th June 2005 11:12 AM |
| Constant input impedance polarity switcher | Steven | Solid State | 13 | 15th October 2003 01:16 AM |
| T-link attenuator with constant impedance | peranders | Parts | 4 | 7th October 2003 12:19 PM |
| Page generated in 0.08605 seconds (70.93% PHP - 29.07% MySQL) with 10 queries |
