Well it generally does, you get 6dB of correction, but if the drivers have a rising response (into 2pi) then the overall response may not be 6dB. However I have seen MMT 2-ways which off axis should be worse than MTM. It begs the question : Instead of completely rolling off the 0.5 way driver, why can't you just reduce its output by say 3dB to 5dB in the midrange compared to the to driver driven fullrange (up to any c/o point). I was thinking about this due to another thread regarding dual Aura NS3's. 0.5 way will work but might sound overall too bass heavy. Running them in parallel requires some BSC, about 4dB according to Zaph, and you'll get inevitable vertical lobing issues with two drivers. However if the lower driver still runs full range, but at lower level, you will get variable BSC, and reduced lobing nulls as the other dominates. Just food for thought, I don't think 0.5 way has to be the full 6dB. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#2 |
frugal-phile(tm)
What you get also depends on amplifier output capabilities. My amplifier puts out ~ the same power into 4 ohms as in 8 ohms so i get about 3 dB from a 0.5.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 | |
No. The voltage frequency response steps by 6dB in the bass for 0.5's at any / all powers. What your saying relates to maximum bass SPL for your amplifier, not the response, and is generally true, not many amps double real power into 4 ohms compared to 8 ohms. The issue I'm discussing is the frequency response, at any level. Consider 2 FR's, 16 ohm each if you want, and manipulating the amount of BSC of a 0.5 way with a variable resistor in parallel with the inductor. rgds, sreten. rgds, sreten.
#4 |
I've gotten various amounts based on the starting curve of the first woofer.
At LF there will always be a gain of 6dB (assuming large choke is similar in DCR). Ideally you will have a 6dB rise for mid frequencies so that you can rolloff the "lower" woofer the maximum amount. If you have less than 6dB rise (in free space, I assume) then you can shelve down the lower woofer a little less to make the midrange level flat with the bass. You probably know that you can only rolloff at less than 6dB per Octave to keep the phase rotation between the two woofers minimized. Also, there will be vertical polar response issues if the lower woofer isn't reduced enough by the right frequency. In the end you need to make the best tradeoff between those factors. Getting bass and mid levels equal is always the overiding concern. Regards, David S. |
#5 |
#6 | |
frugal-phile(tm)
dave
#7 | |
frugal-phile(tm)
dave
#8 | |
You know as well as I do that newbies (and not so new) will assume a CV amplifier. Nevertheless if we are going to be pedantic, your claiming that your amplifier has exactly the right output impedance such that power into 8R and 4R is the same. (For a given input voltage and fixed amplifier gain, which is still not necessarily true depending on the feedback (or not so it can be) topology of any given amplifier). I can't be arsed to work out the implied output impedance because speakers are not constant impedance, and 0.5 way will give you +6dB at a sealed boxes Fs of the two drivers for example. This is just smugness regarding unusual amplifiers at the same time not getting the actual technical details right. Its not on topic. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 8th December 2011 at 08:50 PM. |
| Woofers working together, +3dB or +6dB? | freos | Multi-Way | 122 | 24th March 2012 04:50 PM |
| Baffle Step Loss - Why 6dB? | bmwman91 | Multi-Way | 95 | 19th November 2011 09:26 PM |
| first order filter 6dB down | Marcelinho | Multi-Way | 4 | 17th May 2011 01:00 AM |
| LINE PRE - 6N9S - 6dB | Stee | Tubes / Valves | 0 | 28th April 2011 03:52 PM |
| 6db slope ribbon + driver, possible ? | norman bates | Full Range | 4 | 6th October 2010 10:15 AM |
| Page generated in 0.11010 seconds (81.44% PHP - 18.56% MySQL) with 10 queries |
