View Poll Results: Banana Plugs or direct ?
Plugs 8 50.00%
Direct 8 50.00%
Voters: 16. You may not vote on this poll
Old 7th December 2011, 01:56 PM   #1
Happy Chappy
Fivetide's Avatar
Question Banana Plugs or direct ? + Poll
Simple question, do you think connecting your speakers to the amp via banana plugs is better than wiring them in direct? I can understand them for convenience but I can’t understand how passing those first through something can be better than directly wiring them to the speaker poles.
Old 7th December 2011, 04:54 PM   #2
If you desire a quick change, banana plugs provide that.
More than a few changes of bare stranded wire usually ends up with needing to clean up the wire.
If you want the least resistance, eliminating the banana plug will accomplish that, though depending on the surface area of the binding post, and materials, the banana could actually have less resistance.
A decent clean banana plug will generally have only a tiny fraction of the resistance of the speaker cable used, so the difference between using one or not is generally inaudible, putting the difference down to convenience.
I have amp racks with both hard wired connections and banana plugs, each appropriate for the usage.
Art
Solder style banana plugs nightanole Parts 10 8th April 2010 09:43 PM
PPI plugs - the old flat speaker plugs jol50 Car Audio 0 21st January 2009 09:28 PM
Clarity Caps, Toroids, Banana Plugs ShinOBIWAN Swap Meet 9 7th December 2008 05:50 AM
banana plugs morpheus82 Parts 0 31st July 2006 03:15 PM
Metal chassis and banana plugs (and also RCA): how do isolate them? Bricolo Parts 12 11th August 2003 07:16 PM
Page generated in 0.08298 seconds (77.78% PHP - 22.22% MySQL) with 11 queries
