Altec Lansing VOTT Clones?
Old 9th December 2011, 05:25 PM   #41
weltersys is offline weltersys  United States
weltersys's Avatar
Originally Posted by Pano View Post
Playing as loud as I care to the peaks hit 6V, max. That's 4.5 watts, peak.
Average power is 1/8 watt for 85dB at the listening seat.
I'm curious as to what voltage would be required to hit 100 dB at 30 Hz at your listening seat, measuring your modified A7/5's fundamental, not harmonics.
Old 9th December 2011, 06:13 PM   #42
GuidoR is offline GuidoR  Italy
GuidoR's Avatar
This F5 with 2SK2013/2SJ313 is my - very personal - version of Altec VOTT.
I like the fast (very light cone) woofer, the only issue is the limited maximum admitted power. However, with a good (well-damped) class-A (Pass' F4, F5 or alike) the lack of bass is negligible, and the pleasure maximum.
And yes, the horn is all but well damped, (if striked it rings like a bell), but the sound is sweet.
If I would build today a similar system, I'll be curious to try these drivers B&C SPEAKERS (in fact, I had the opportunity to listen to them in a commercial product, and they are really amazing).
Anyway, I'm very happy to listen to my little Altec babies (that are as old as me )
Guido
Old 9th December 2011, 09:03 PM   #43
Pano is offline Pano  United States
Pano's Avatar
Probably a lot, as they roll of higher than that.
Old 9th December 2011, 09:41 PM   #44
weltersys's Avatar
Yeah, looking at Tom's before and after graphs, looks like the stock A7 rolls off around 120 Hz, and the "after" rolls off from 60 Hz.
Such a huge cabinet for so little low frequency.
Old 10th December 2011, 01:08 AM   #45
Pano's Avatar
Yeah, it's a crazy big box not to go down lower. Tom's graph looks about like what I got with the original ports. After some work there and I'm down to the mid 40s. I "think" there's another ~10Hz to squeeze out if the ports are right. More work to do.
The trade off for me is the naturalness of the sound. It's a box that does not sound like a box - it sounds like real acoustic instruments. And that's what I like.
Take the Speaker Voltage Test!
Old 10th December 2011, 01:21 AM   #46
ke4mcl is offline ke4mcl  United States
i run altec 9864 cabinets in my livingroom. they are biamped. i use a dbx 2 way electronic crossover and drive the cabinets with Mc tube amps. i would call these a coaxial version of the VOTT idea.
i love them. yes, they are not the most accurate. they also dont come alive until played loud. the cool thing is loud comes easily. 20wpc and you are having a party. when i first brought them home i took a bare ended headphone cable and used a single AA battery driven minidisc player to drive the speakers loud enough to hear the music in a room. the size of the cabinets is part of the efficiency.
AFAIC for vocals, brass, and guitar nothing beats horns.
info on these speakers can be found here..
http://www.altecpro.com/pdfs/vintage...r%20System.pdf
certified packrat
Old 10th December 2011, 07:35 AM   #47
GuidoR's Avatar
I totally agree, it's the magic of Altecs
Old 10th December 2011, 12:04 PM   #48
speaker dave is offline speaker dave  United States
speaker dave's Avatar
I don't have the room for these kinds of systems but I can certainly see the appeal.
I'm involved in professional theater design and install these days. The A7s and such that you guys like are just the cinema systems of a particular era. Pull out the articles by Shearer or Hilliard going back to the 30s and read the history. It is facinating and highlights where real loudspeaker science had its orrigins.
The modern trend has been that big power is cheap so horn loaded LF is just not used any more. A pair of 15s in a large cabinet will give you much wider bandwidth and smoother response. The upper bass efficiency kick and higher directivity of a short horn doesn't buy much in a domestic environment.
Don Keele shows the comparison between folded bass horns of reasonable size (a W bin) and 2 or 4 15" woofers.
http://www.xlrtechs.com/dbkeele.com/...%20vs%20DR.pdf
What I typically install in a mid size theater would be from the JBL 4675 family.
JBL :: Product
http://www.jblpro.com/catalog/suppor...pe=3&docid=634
Drivers are smooth and the directivity is very even so a little bit of EQ gives great response and coverage over the seating area.
My advice: a pair of 15s in a good vented box and then find your favorite horn and driver. Electronic crossover and good EQ and you are set.
David
Old 10th December 2011, 12:28 PM   #49
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
David
A horn system does have it impuls behavior and directivity that a isn't the same a BR or Onken.
Here the modern BR-layout idea for passive approach. Acive would be compact closedbox low with enough power to get the same spl and dsp technology to correct low response down to 20Hz.
http://www.diyaudio.com/forums/multi...ml#post2807789
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 10th December 2011, 02:04 PM   #50
Pano's Avatar
Yep. The A7 was Altec's small speaker for small cinemas. Sure were a lot installed. At an audio show I met a guy who had pulled more than 20 of them out of an old multi-pex in Arizona. He sold them off slowly and paid of his house.
Have you worked with the new 3000 and 4000 series? The ones wit the horn loaded 6" mid? (3730, 3731) I'm curious about those.
I do like twin 15 cabs a lot. Thought about building one, as I have 4x Altec 416-8A.
Altec Lansing VOTT Clones?Hide this!Advertise here!
FILTER cabinet VOTT ALTEC sigurd Multi-Way 0 16th July 2009 12:16 AM
Altec A2 VOTT / or how to blow your neighbors away.... RacerXtreme Multi-Way 27 2nd September 2008 09:01 PM
Altec VOTT on Minneapolis Craigslist: $300 pjanda1 Swap Meet 1 15th May 2007 08:28 PM
Copyright ©1999-2017 diyAudio
