No sub = no bass... true? - Page 14 - diyAudio
Old 22nd December 2011, 02:57 PM   #131
picowallspeaker's Avatar
#1- Work the room first, identify modal problems and try reducing reflexions;
Find a room ( or outside ) that is BIG so the BIG LONG WAVE of bass won't get interrupted ( reflected ) by boundaries
# Go to a cinema
Old 22nd December 2011, 06:49 PM   #132
#2- Distribute bass sources, up to 3 even 4 subs may be required;
#3- If dips and peaks are still too proemininent, fine tune with an Eq;
#4- Do all of this with measurement instruments;
#5- At the end, (globally) adjust to taste.
#6- Sit, listen, enjoy, FEEL the music
One thing I'd like to add is that main speakers with poor crossover balance can take away the perception of bass. If there's even 2db too little baffle step compensation, the perception of bass seems to disappear no matter who physically capable your setup is.
Old 31st December 2011, 03:59 AM   #133
I made myself a late X-mas gift; I've found a Tannoy TS-12, and I received my Dayton EMM-6 and Behringer 802 today. I started fiddling around. It's very interresting to see what can be done with adequate measurements.
Martin.
Old 31st December 2011, 08:09 PM   #134
Inductor's Avatar
Originally Posted by Inductor View Post
Martin,
IT'S TOTALLY WRONG!!!
and here is a video to prove it.
Grande Utopia EM from Focal - YouTube!
(Note: If the quality of the sound of this video is good is because you have good speakers at home and don't need a sub or new speakers).
I've found a thread worth reading to help solve my bass problem... Multiple Small Subs - Geddes Approach
From what I've learned through this tread and elsewhere, "no sub = no bass" is untrue...
THANKS!...
Old 31st December 2011, 10:24 PM   #135
Martin.
I feel like I may have already posted this in this thread, but just in case I have not, I recommend taking a read of the following:
http://www.infinitysystems.com/home/...nf-rooms_3.pdf
Old 31st December 2011, 11:45 PM   #136
AllenB is offline AllenB  Australia
canonnica, I'd also like to point you to the other thread, third post, where Geddes describes the procedure step by step. I feel that it can be approached in a few different ways but generally within the framework of the above description.
Old 31st December 2011, 11:58 PM   #137
pski is offline pski  United States
From what I've learned through this tread and elsewhere, "no sub = no bass" is untrue. But poor room = bad bass response = TRUE.
High-level steps seems to be, in this order:
After the DD's came out, it was interesting that so many reviewers were using their calibration on other products . .
Paul
Is it really true!? humlan57 Full Range 10 11th January 2010 11:47 PM
Is it true? rick57 Digital Source 4 31st October 2006 09:50 AM
is this true???? kathodyne Tubes / Valves 16 29th January 2006 11:26 AM
True....true!!! mikeks Everything Else 4 18th June 2004 03:51 AM
Is this true? josefr Digital Source 3 9th April 2003 10:28 PM
Copyright 1999-2017 diyAudio
