Apollo Construction Diary
Old 11th May 2013, 05:24 AM   #651
Mark_A_W is offline Mark_A_W  Australia
It came out really well.
Old 17th May 2013, 01:09 PM   #652
ShinOBIWAN is offline ShinOBIWAN  United Kingdom
ShinOBIWAN's Avatar
Small update on the One.20
Apollo Construction Diary-20130517_121755-jpg
Apollo Construction Diary-20130517_121728-jpg
The more you know who you are and what you want, the less things will ever be the same.
Old 17th May 2013, 02:51 PM   #653
sploo is offline sploo  United Kingdom
Originally Posted by ShinOBIWAN View Post
1.5mm DOC, 800mm/min and 9000rpm with a 6mm single flute cutter. This is about the quickest you can go if you want a good edge finish. I have had it at 3mm with 1m/min but was getting deflection of the gantry/cutter. Any more than that and I think it would significantly shorten the life span of the machine or you'd start breaking cutters.
You can get by cutting aluminium on these CNC routers and get some nice results with the right cutters being careful to dial in your feeds and speeds but I wouldn't fancy doing it often on larger jobs. Its fine for things like amplifier plates and such though.
Thanks for the info. That's faster/deeper than I was expecting TBH. What's the cutter you were using? I suspect my carbide spiral cutters would be capable of alum, but they're 2 fluted.
I've got a couple of (non-loudspeaker) related ideas I'm considering, and I'd love to try them in aluminium. They're small, so I would be happy trying just 1mm DOC, but I'm worried my router may not be too great at 9000rpm.
Nice. I particularly like the sock/underpants support for the front baffle .
Old 17th May 2013, 03:04 PM   #654
ShinOBIWAN's Avatar
The secret to high end audio has been revealed!
Old 17th May 2013, 06:52 PM   #655
ScottG is offline ScottG  United States
..underpants support for the front baffle .
Well, it is under the crotch of the loudspeaker, no?
perspective is everything
Old 17th May 2013, 08:01 PM   #656
ShinOBIWAN's Avatar
Rhodium plate 'em and folks will lap 'em up. Every pair of loudspeakers will be wearing keks
Old 21st May 2013, 06:51 PM   #657
Hsmeets is offline Hsmeets  Netherlands
wow: Rockport Technologies
Old 21st May 2013, 08:18 PM   #658
Originally Posted by Hsmeets View Post
Not sure TBH. Aesthetically, they look a little "flabby", but I guess that's just my opinion.
The irony is that they appear to be constructed from carbon fibre, but weigh 900lbs each, which is kinda not the point with cf if you think about it .
Old 21st May 2013, 08:33 PM   #659
before someone would think this, i'm NOT trying to accuse anyone from anything. I thought and still think that designwise the Apollo and siblings are damn fine pieces of work. And for the record: I like Shin's much better.
Old 21st May 2013, 09:13 PM   #660
ShinOBIWAN's Avatar
Its getting to my favourite part of any build. Spraying! I've been agonising over colour choices for more hours than I dare admit. Here's the one's that I've settled on.
First is a metallic black, which is a little more interesting than the usual straight gloss black.
Apollo Construction Diary-20130521_212545-jpg
Apollo Construction Diary-base_metallic_black_custom_paints-jpg
Pearl white. For such a simple colour I've had a hard time tracking down the one I wanted. Most of the pearl whites are slightly creamy and I was looking for a clean looking white.
Apollo Construction Diary-snow_white_pearl_base_custom_paint-jpg
Not so subtle here is a deep red candy tint over a shimmering silver. Looks stunning in the flesh.
Apollo Construction Diary-20130521_212945-jpg
Apollo Construction Diary-deep_red_candy_www-specialistpaints-com-jpg
And finally a blue pearl.
Apollo Construction Diary-blue_grape_pearl_custom_paints-jpg
File Type: jpg Deep_Red_Candy_www.specialistpaints.com.jpg (81.1 KB, 815 views)
Apollo Construction DiaryHide this!Advertise here!
