Apollo Construction Diary
Old 19th April 2013, 01:45 AM   #621
SirByrd is offline SirByrd  United States
SirByrd's Avatar
What was your feed-rate like where you were breaking cutters?
Old 19th April 2013, 01:51 AM   #622
ShinOBIWAN is offline ShinOBIWAN  United Kingdom
ShinOBIWAN's Avatar
Anything upward of 300mm/min was asking for trouble. Too slow and the cutter gummed up and broke. I found 250mm/min worked fine for me with a DOC of 0.075mm and total depth of 0.15.
The engraving bits are 10 degree and almost needle like. Very fragile.
A kind soul recommended a diamond tipped drag cutter as used in vinyl cutters for this sort of job. Much harder to break.
The more you know who you are and what you want, the less things will ever be the same.
Old 19th April 2013, 01:54 AM   #623
SirByrd's Avatar
Wow, hope they weren't expensive. No manufacturer specs for feed rate? I'm a CNC noob, so I don't know if that's a thing or if it is totally dependent on the cut you are doing. Seems odd there would be a minimum feed rate.
Old 19th April 2013, 02:04 AM   #624
ShinOBIWAN's Avatar
No not at all really. They were these:
5 x Carbide PCB Engraving CNC Bit Router 10 Deg 0.1mm | eBay
I bought a bunch of them knowing I'd probably break a few. Your feedrate is determined by lots of things including the machine, material, depth of cut/step over, finish quality and so on. You sometimes get generalised advice for common materials but really you'll have to play around until your getting results.
Old 19th April 2013, 02:05 AM   #625
ShinOBIWAN's Avatar
I should be using one of these instead of the engraving bits:
SIGN VINYL DRAG KNIFE & ENGRAVING BIT CNC END MILL VACUUM TABLE VINYL CUTTER | eBay
Old 19th April 2013, 02:06 AM   #626
SirByrd's Avatar
Awesome, thanks.
Old 19th April 2013, 06:08 PM   #627
ShinOBIWAN's Avatar
With the black lettering. These still need clear coat to finish them up.
Apollo Construction Diary-rear-panel-02-jpg
Daylight shots of the Apollo plates. You can see the fine brushed finish looks almost satin. Really pleased with these.
Apollo Construction Diary-apollo-rear-panel-04-jpg
Old 19th April 2013, 06:38 PM   #628
badman is offline badman  United States
badman's Avatar
Great looking plates. A couple suggestions-
1) You may wish to tweak the spacing to allow dual bananas. This would have the added benefit of grouping the HF/LF inputs together more closely than their vertical spacing, making the wiring more intuitive/foolproof.
2) I'm a big fan of the cardas patented single-knob binding posts for spades. You may want to consider these, they're a very elegant UI for input wiring on a loudspeaker.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 22nd April 2013, 08:23 PM   #629
ShinOBIWAN's Avatar
Completed:
Another alu plate for the hidden connections between cabinet sections. Finished in matt black:
Old 22nd April 2013, 11:25 PM   #630
_henry_ is offline _henry_  Australia
shin, i cant see the pics on your last post
Apollo Construction DiaryHide this!Advertise here!
