#531 | |
Thanks for your reply. I'm just impress of how you build your speaker baffle. It looks so nice! The cnc that you put up together made it easier and quicker cutting the pieces compared to miter saw. I already build my cnc but haven't tested yet. It's smaller compared to yours, but I'm planning to use it on cutting aluminum for front/back panels of amps and drilling holes. If you don't mind asking you, how much did you spent building your cnc? |
#532 | |
The more you know who you are and what you want, the less things will ever be the same. |
#533 |
Tweeter parts cut today. They're all assembled and glued but clamped and drying at the moment so I'll get a shot of those completed tomorrow.
Been playing with the CNC feedrates and depth of cut now I'm feeling a little braver. Trying to find the limit then from there I can back off for some safety margin. Currently upto 6.5m with 9mm depth of cut and it handles this no problem. Little worried about snapping the smaller 6mm cutters with much more than this though. Still haven't figured out how to do ramping in the CAM software yet though. Its there but I've only took a quick glance at the settings so far. Will invest more time in it at some point because although its only MDF at the moment if I'm doing a straight plunge into stuff like Alu then its gonna knock the hell out of the machine. Apollo Tweeter Enclosure Cuts - YouTube ![]()
The more you know who you are and what you want, the less things will ever be the same. Last edited by ShinOBIWAN; 11th February 2013 at 11:57 PM. |
#534 |
This is looking really good now. The bracing reminds me of the Magico stuff except in MDF. I'm looking forward to seeing the finished product now. Can I inquire as to what it would cost or a set of these boxes? Not including drivers and crossovers. I'm curious since my wife actually likes the look of these speakers. And that is a BIG plus for me.
#535 |
Its been an eventful day.
Broke my first bit through going too fast too deep. Its a bad idea to try 7m/min at 12mm depth with a 6mm bit. Bit stupid of me really since I've been told stick to around the diameter of the cutter as a safe area. Before the cutter broke I also noticed the quality of the finish starts to suffer when you go too far, sure the machine might move the cutter through the material no problem but its not rigid enough to handle those forces and that translates to the cutter and the work piece. After the self inflicted drama the rest went smoothly. They're starting to take shape now. This is one big speaker. Its testament to the fit of the bracing and rebates that none of this is glued or fastened in any way yet it still stands under its own weight. Pretty cool. ![]() ![]()
#536 |
Fark I just made a mess
#537 | |||
How is that spindle holding up BTW? Oh - your ducting is a little small for the static pressure loses over the lengths you have (you'd need a serious extractor to capture fine dust). However, the fact you've got the machine in an enclosure (which I presume is essentially sealed - albeit with an inlet valve - when you're cutting) is arguably better than any level of extraction, so I wouldn't worry. I would however strongly recommend one of these http://www.trend-uk.com/en/UK/produc..._230v_uk_.html for the period when you're getting bits out of the machine and cleaning it out. It's made a huge difference to my cutting (well, lungs and eyes) and I wish I'd bought one years ago. Quote:
.Perhaps I could PayPal you some cash for postage + beer and you could chuck some in a box? Quote:
Also, deep DOC obviously gives more bit deflection (OK, fast linear does too), but for cuts that'll be visible you'd want a full depth finishing pass anyway. Speaker looking absolutely superb, and yea - CNC is great for putting a box together to test with no glue. Got to say, what impresses me about your work is that the reality usually ends up looking like the render! My design process is usually back-of-fag-packet -> 2D drawing -> gcode -> MDF -> glue it -> run out of time to paint/veneer -> box sits in the livingroom under a table .Oh - what's the tool changer system you've got? It's something that I've never set up, and has always limited me when it comes to doing designs. It's such a faff to change a bit half way through a job that I usually compromise by trying to cut with only one. |
#538 |
HOLY CRAP!!! That thing is huge. I could tell from the render that it was big, but seeing it together in a room brings a better sense of the size. Patiently waiting for it to be finished and hear your listening impressions.
#539 |
More cutting today. All the panels for the cabinet parts are now done. I'm moving on to the grills now and last off will be the base plinths and feet.
Last of the cabinet parts complete: ![]() Grill frames for the 10" subs (the holes in the back will house neo magnets to secure the grill)
#540 | ||||
Hey Gordon,
The spindle is great. Brilliant even. Never struggles and I've done silly things like rapid at 10m/min with a 12mm diameter cutter at about 15mm DOC and with the spindle running 11000rpm lol That was pretty scary and I hit the estop sharpish but even then it had carved about a foots worth of destruction. Its amazing how quickly things start to go wrong. I think even if you had the estop button between your buttocks you'd still not react quick enough ![]() As far as the reliability goes you'll have to come back and ask in years time. I've heard the spindles are robust in the long term but the VFD is pot luck and can be problematic. Mine is holding up ok with the couple of weeks its been working. Early days yet though. Quote:
And yes the enclosure is sealed where possible. I took all the lexan panels out and lined the edges with closed cell foam to help with that. Even without a dust shoe virtually nothing escapes when cutting and the are doors closed. Quote:
SprayDirect.co.uk | 3M Disposable Mask The old man gets them from work for nothing so I've use 'em for a few weeks then throw away. Quote:
Link to the screenset: The CNC Woodworker - Mach3 2010 Its about £13 but the best money I've spent on the CNC by far. Here's a nice video that shows how it all works: Mach3 2010 Screenset Tool Change - YouTube
