Apollo Construction Diary - Page 49 - diyAudio
Old 27th January 2013, 11:05 PM   #481
Looks nice! Is one of the dust collection hoses to the cnc just to pull dust out of the entire enclosure? I was thinking about trying to set up a kind of down draft table on my router plus a dust shoe. Anything not picked up by the dust shoe would get pulled to the sides of the table and down to a collection point with a dust hose. In any case, I'd be interested in how the dust collection works out for you.
Old 27th January 2013, 11:45 PM   #482
ShinOBIWAN's Avatar
Hey John
A dust shoe will go on there eventually(likely the first useful part I cut) but MDF is terrible and you'll never get 100% extraction so the enclosure keeps what's left leaving you to clean up when needed. Its a simple job - pull the hose off the shoe and run it around to pick up the left overs.
Not sure about a down draft table. Depending on the number of holes and open surface area you might need go with a large blower and these can push a lot of the dust back out into the workspace. Because of my simple setup I went with a vacuum extractor. Like I said there's lots of question marks surrounding proper filtering of fine particles with the blower extractors. Even with pleated filters they're still only catching 1 micron and larger particulates 90% of the time. MDF particles can go down to as small as 0.5 microns and if, like me, you've got an extractor in your workspace then you'll really want something that can handle those. Good vacuum extractors will do 0.5 microns at 99%+ efficiency.
I was amazed how complicated proper dust extraction is. There's really no one stop solution for every situation. What I have is a compromise but its about the best I could manage on my budget and particularly the noise levels I was willing to put up with. Vacuum extractors can be very noisy! I demo'd both a dual and triple motor model similar to what I have these things could handily beat any horn loaded or multi driver array SPL monster out there! As you might imagine the quieter one's don't pull as much air so there's your compromise.
The more you know who you are and what you want, the less things will ever be the same.
Old 28th January 2013, 12:14 AM   #483
I had a shop vac on my router and used it like you say - pull the hose off the dust shoe to clean things up. This left a lot to be desired, partly as I didn't have the machine enclosed. What I was looking at upgrading to was something like this with an enclosure:
CVMAX - Single Phase with Filters - Clear Vue Cyclones
These have 99.99% at 0.5 micron filters, or you can upgrade and get 99.999%. I worked at a place that had two of these in their shop, and while they did make a fair amount of noise they didn't seem that bad. Cutting noise was louder than the dust collectors.
Old 28th January 2013, 01:57 AM   #484
Originally Posted by ShinOBIWAN View Post
I made a video for Arthur whom the Apollo are destined for. I'm sure he won't mind me posting it here though. Apologies for sounding confused and bunged up. Its my first time talking to just a camera (felt really weird!) and I hadn't really thought about anything before hitting record so its random to say the least!
Rambling about CNC - YouTube
LOL cool!
Out of interest do you know if the Valchromat can be finished on an exposed edge or if everything has to be painted?
Old 28th January 2013, 03:27 AM   #485
ScottG is offline ScottG  United States
Like it!
More, more!
perspective is everything
Old 28th January 2013, 07:11 AM   #486
ShinOBIWAN's Avatar
Originally Posted by smallangryboy View Post
LOL cool!
Ask me in a couple of months when I try spraying it
When you say finished do you mean filled and sanded? If so then yes and no. You'll still have to sand the edges but filler wouldn't be needed.. The faces are polished and pre-finished though so if you are painting you'll have an easy time compared to mdf.
Old 28th January 2013, 07:15 AM   #487
ShinOBIWAN's Avatar
You'd have no problems with that setup John. Its pretty much as good as it gets for our setups. I say if you can afford it and have the space, then go for it.
Old 28th January 2013, 05:28 PM   #488
badman is offline badman  United States
Custom Title
badman's Avatar
Your construction should move a lot faster now- very cool, nice work getting that CNC up to what seems to be a very high standard.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 29th January 2013, 11:39 PM   #489
ShinOBIWAN's Avatar
Will be interesting to see how this goes when cutting for real!
First Air Cut Attempt on CNC - YouTube
Old 30th January 2013, 10:36 AM   #490
Originally Posted by Old'n'Cranky View Post
Hmm. i wonder.
Wish I'd found all this sooner.
Been trying to find hd mdf for the last few months to use in my current speaker project.
Ended up with 32mm mr mdf sent to my cabinet maker.
I haven't had time to look at the links, but I'm pretty sure it hasn't been anywhere for that long. It's only newly available in the UK which is the first market AFAICT.
Moisture resistant MDF is the best alternative I've been offered too. Higher density seems to be unavailable. I guess I don't know the right cabinet makers :-/
EDIT: Hmm, your links indicate otherwise. Could be good news. Time to investigate, thanks!
Copyright 1999-2017 diyAudio
