#221 | ||
#222 | |
I've tried all sorts of which ways using the floor plan and what I've got is the most efficient use of the space if not the most practical. |
#223 |
#224 |
The cnc has been delayed because the control box still needs wiring and then testing. Its now going to be sometime next week. Shame, I was looking forward to playing.
They've sent a few more images which shows the machine is pretty much complete. ![]() ![]() ![]() I've also designed a simple mitre saw trolley constructed out of 40x40mm alu extrusion. Should be an easy but very sturdy build. The whole thing is on casters too because with a small workspace its important to keep things flexible for when you need that little extra room. Parts sourced from these guys: Valuframe - Aluminium Extrusions > Aluminium Profile > Aluminium Extrusion > Aluminium Profiles >Aluminium Profile Systems ![]() ![]()
#225 |
Sorry to hear the machine is delayed. Looking good though. Well, the machine looks good. You'd think with that level of tech they'd be able to afford a decent camera to take pics to send to customers
.Trolley looks good - and thanks for the link - I've been looking for a decent supplier of extrusion material. Are the prices ok? |
#226 | ||
![]() Quote:
#227 |
I've been thinking some more about keeping down the dust and from reading around the web I don't think my current extractor is going to be up to the job. Its rated at 1000m3/hour and was recommended by the place that sold me the table saw. But reading in between the lines its never going to supply that air flow and so within a ducted system, and if you took care to minimise leaks, you'd expect that figure to drop by around a quarter. That isn't much at all when your talking about a table saw or router. Folks with fancy manometers are recommending upwards of 1500m3/hour actual air flow for table saws - about twice as much as I currently have.
Another complication I've stumbled upon is the table saw is ideally suited to a high volume low pressure type of extractor. These are generally the blower models and move lots of air but more gently. And the router definitely needs to get stuff away as fast possible so a low volume high pressure vacuum type extractor would be better. Axminster have a large range of machines so I rang them up and asked for their advice on what that would be suitable for both the table and the router. They came back at me with this suggestion: Buy Numatic NVD750 Workshop Vacuum Extractor from Axminster, fast delivery for the UK However I'm somewhat confused. The specs state air flow is rated at 350m3/hour although the pressure would be much higher than my current unit because that particular model is a vacuum type rather than a blower. It looks fine for the router but surely not for the table saw? I'm confused ![]() I figure this machine I already have isn't going to pick enough up for my liking but instead of going out and risk buying another turkey could those in the know suggest a suitable unit for what I'm wanting to do? Budget is £400 but would be great to come in under this. Edit: Relatively low noise would be big bonus too Last edited by ShinOBIWAN; 10th February 2012 at 10:15 AM. |
#228 |
#229 |
If you've never read it before, Bill Penz's site might be of help: Bill's Cyclone Dust Collection Research - Home Page The executive summary is something like: small dust collectors that don't move enough air work for chip collection but leave fine dust in the air which can cause serious health problems.
I'm eventually planning on buying one of the Clearview cyclones for my router. We had a pair of them in the shop at my last job and they were nice. They're around triple the air flow of your current model, but also more expensive it looks like. |
#230 |
Hi John
The cyclone type do look ideal however they're way beyond my budget. They start at £1500 and go up to £££. I've got £400 max and risk loosing valuable man appendage if I spend more ![]() This is about the cheapest I could find new: Buy Axminster Industrial Series UB-2200VECK Cyclone Extractor from Axminster, fast delivery for the UK Maybe something will come up on ebay but its not really a common item and I could be waiting a long time. I do understand what your saying about fine dust getting kicked back out the filters and into the air. Its a real problem with MDF. But you can get fine filters that work down to as little as 0.2microns which will prevent that. |
