#201 | ||
Because I find it fiddly to cut double sided jobs on the CNC, I sometimes cut the rear of a speaker baffle (rebates and slots for construction, as well as driver and port holes). I'd then cut the driver rebates with a rebate cutter (by hand, or on the table, for a smaller baffle) as well as roundovers for port holes, and then roundovers on the edges of the glued box. |
#202 |
That a good tip on trimming tabs. I'll have to remember that one.
#203 | |
For large parts, this is fine, as you can roughly cut the piece out with a knife, jigsaw, or bandsaw. Then I clean it up with a trimming bit, just as I would do with tabs. It seems to leave a better edge. For smaller parts, it's a bit more of a faff, so I might use tabs. |
#204 |
A quick update on Apollo baffles.
The construction of the baffles has evolved into a Corian outer shell with an MDF core and the two are coupled with a visco-elastic adhesive layer. That's obviously a lot of very complicated machining and pretty much requires a 5-axis machine to do sensibly so the parts I've designed have been outsourced to a Corian fabricator near me. Maybe once I'm really confident with my own cnc I'll give similar things a go but for now Corian is far far too expensive to make a mistake with The Corian place have done a couple of prototype baffles now just to verify with me that I'm happy. The first attempt had some issues but this evening I got to check out the second iteration and I gotta say the results are fantastic. Extremely dead resonance wise and the Corian looks and feels great. The complete set are now in the works and once done you can bet I'll be posting images back here. |
#205 |
Since you've already done it, it doesn't really matter but I don't remember seeing anything on your baffle design that required more than 3 axes to machine. I also know people who do machine corian on their routers. So for the future, it would definitely be worth a try. If it's expensive I'd definitely get your process down using some mdf first and then adjust feedrates for corian as required. I have not cut corian myself, but iirc it requires lower spindle speeds or higher feed rates to prevent melting it. I'd assume you have to polish the faces you machine to get the finish back.
#206 | |
Then consider your doing that for six parts, four of them very large, and its a huge amount of labour and time. The 5 axis cuts down the machine time by a huge amount and negates the need for sanding all edges and surfaces because the end mill would be perpendicular throughout the process rather than using a step over approach which leaves thousands of tiny ridges on the work piece. Some jobs only make sense with a 5 axis machine even though you could do them on a 3 axis. If I were doing this on the 3-axis, I'd skip the MDF core and visco layer. A block of corian would be far simpler and quicker at that point. Last edited by ShinOBIWAN; 3rd February 2012 at 07:25 PM. |
#207 |
Arthur has asked for the option to allow for some experimentation with tweeters.
The original intent is for the RAAL 70-20 but flexibility never hurts and so I've fashioned up a tweeter baffle that allows most standard 104mm diameter tweeters to be installed. The target here is the Scanspeak D30 series and most likely the beryllium variant. Swapping between these two is a matter of a few bolts, slide out one baffle, replace with the other and fix back up. For the sake of completeness here's another render of the with dome tweeter variation.
#208 |
Shot of the prototype baffle. The final one's will be shinier!
Looks awesome in the flesh. Once I have the finished articles I'll get some better shots.
#209 | |
Superb!Re 5 axis - yep would kill for one of those, plus an autochanger. There's a bespoke furniture manufacturing place not that far from me, and they use a 5 axis CNC set up to do some amazing 'quilted' sheets of wood, which are then veneered. I got chatting with the guy about their techniques, and he lead me to their 'barn'. In it was a machine. A big machine. As in, you could comfortably fit two medium sized cars on the bed. The cutting head weighed more than my whole machine. Yep. I'd kill for 5 axis plus an autochanger |
| Page generated in 0.09087 seconds (72.73% PHP - 27.27% MySQL) with 11 queries |
