#11 |
Hi Linesource and Tim,
Thanks for the suggestions. The modular route is something I've played around with in the past and will no doubt do so again in the future. This particular project is pretty much bespoke but for the more realistically sized speakers its definitely worth looking at again. Its a good challenge to get all the individual components within a modular system designed well on all levels and both with each other and as separates. Once you've found that however I agree its very appealing. |
#12 |
If your not up to the challenge, I can always arrange for some tea-chests to be shipped over to you to make a modular system more within your reach!!
Even then 'damping' the cabinets might prove slightly problematic. |
#13 | |
Custom Title
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#14 |
Hi Shinobiwan,
As much as I admire your work, I would take the separate subs advice to heart. Impressive as the speakers physically and hardware-wise are, in sub-bass they are -as most integrated high enders- rather fighting the room than melting into it. Welti and others have shown the way. Good luck. Eelco |
#15 | |
Custom Title
#16 |
Hi Shinobiwan... that is some serious pair of speakers! I really like your choice of drivers and materials... A true SOTA project
I know that the design is more or less frozen at this time so I will not dear to propose any changes But anyway, have you concidered using constrianed layer damping (visco elastic glue) and vibration dampening of the driver chassises? br, and good look with the project! |
#17 |
Appology for OT, I could not resist: "The Good, The Bland, and The Ugly"
#18 | |
Thanks for your post. I can see where your coming from but these are in better position than the usual cabinet with a single driver mounted a foot or two above the ground. You've got that and you've got another closer to the ceiling and then that driver array is mirrored on the other side of the cabinet. Add to that another cabinet for stereo and you've got eight subs located in in different position across the front of the room. The type of problem your talking about will always only be addressed with separate subs at the sides and rear of the room and that's beyond the scope of a stereo pair and moving more into room acoustics analysis and problem solving. Its possible to add subs to this to achieve this of course. |
#19 | |
The drivers have magnet braces which will calm that sort of thing. AT drivers are well built and solid too. There's no constrained layer approach but I do use 9mm + 18mm laminations for the walls and then further line the interior walls with 2mm lead sheet and 2mm bitumen. This along with fairly extensive bracing gives a significantly resonant free cabinet. The baffles are Corian which is basically a composite of 1/3 acrylic mixed with 2/3 bauksite and then heated together. Its a superb material for loudspeaker applications but is expensive and difficult to machine. |
#20 |
| Page generated in 0.08074 seconds (70.76% PHP - 29.24% MySQL) with 11 queries |
