I am considering to build my own set of speakers, i have two candidates
as of right now, the first i a corn scala mod 3, second choice is a solution with onken bass bin with altec 416 b + Jabo KH-53 horn with either a fostex D1405 or a BMS 4590 i am not shore if these drivers fit together or were i should set the crossover maybe around 600 ? any input ,suggestions on my project would be grately appreciated i will use a furniture carpenter for building of the cabinets |
#2 |
Ok, jumping in with both feet, I see! Those are very ambiguous first projects.
I have a soft spot for the Onken, so that's what I would recommend. I don't know the horn, but 600-800Hz is usually where the Onken/416 is crossed. Measuring is the best way for the crossover, it's stab in the dark without it. It can work, but may not be optimum. Those two compression drivers are very different and not interchangeable.
Take the Speaker Voltage Test! |
#3 |
Banned
If you want assistance, I suggest you provide links so members do not have to do a search themselves.
#4 | |
tnx, i appologize D1405 - Fostex horn driver - Europe Audio Overview Seitentitel
#5 |
#6 |
I use the KH55 sound very nice with beyma 2 Inch. I would like to use a 18 sound 2 inch.
ND2060A - HF Neodymium Driver low I did a nice symulation on the beyma 15lxv60v2 a basreflex low and loud 97-98dB -3dB 30hz!. See rearport gain for the output of the BR-port this ads to the response in the first graphic. http://profesional.beyma.com/ingles/pdf/15LX60V2.pdf
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet Last edited by Helmuth; 5th December 2011 at 06:59 PM. |
#7 | |
tnx |
| Best First DIY Project | Netdewt | Construction Tips | 1 | 1st March 2010 09:33 PM |
| Vinyl Archiving Project - To DIY or not to DIY | neilmacey | Analogue Source | 4 | 3rd September 2009 05:58 PM |
| First DIY Project | Jameschoi | Pass Labs | 10 | 16th February 2009 09:27 PM |
| First DIY Project | DIY_newbie | Multi-Way | 14 | 28th May 2004 10:10 PM |
| Page generated in 0.10397 seconds (77.98% PHP - 22.02% MySQL) with 11 queries |
