I would like to ask which is the polarity to wire a tweeter to the crossover ?
The crossovers are 2nd order, Butterworth, with the addition of a resistor 1 ohm in series with high-pass crossover input +. I replace the tweeters and i am not sure for the right tweeter polarity because the sound differences are "audible". If anyone knows, the speakers are Celestion, Impact series. The new tweeters are SEAS T25CF001. Last edited by reveonss; 5th December 2011 at 04:41 PM. |
#2 |
hello , you haven't specified if it's a 2 - way or 3 way loudspeaker system .
Usually , in 2 way the tweeter is mounted 'out of phase ' , for a 2nd order highpass , because at crossover frequencies the signals would sum , and being 2nd order filters 180 ° phase shifting , putting the tw reversed would bring the emissions to optimum . Different for a 3 way system , where often the midrange is reverse -phased , and the tweeter 'normal' . |
#3 |
Thanks for your ansuer.
Sorry for the omission, the speakers ways are 2, bass reflex and the crossover point 3000 Khz. I think is not so easy to end up in correct or reverse tweeter polarity. With tweeter reverse polarity, sound is soften but the program is not so real. Image focus is better. With the other way, (right polarity), sound is so real, the image lighter, but i listen spikes in high frequences. Last edited by reveonss; 5th December 2011 at 06:01 PM. |
#4 |
Driver polarity depends on the final acoustic roll-offs of the drivers, not the electrical order of the filters, so it depends on design. FWIW those Seas tweeters seem far too expensive for the application, and the extended low response may be mucking up the phase tracking. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#5 |
diy newbie
I would try both ways.... in my projects there is no right or wrong way untill its been listen to.....
#6 |
Dear friends...
I think that i must be more specific about this constraction. After the tweeters, I will also change the woofers with something better, maybe SEAS or SCANSPEAK and finally I will make new boxes with analog litters. Crossovers are adjusted with other materials (coils, capacitors) in every speaker driver change and I will probably make a new crossover using measurement software. I totally agree with previous statement that, "driver polarity depends on the final acoustic roll-offs" and this should be the good result, to be able to listen well and not only have right measurements. In this case, I've had better results when the tweeter's polarity was inverted. Last edited by reveonss; 6th December 2011 at 05:11 PM. |
#7 |
I have to say that I prefer the first order irregularities and power handling compromises to the second order flip of high frequency overtones for the sake of flat frequency response around crossover. For me the first sounds realistic though distorted; not "real" whereas the second is just not engaging therefore not "real" either. An old conversation but also a line in the sand.
#8 |
#9 |
I'm using a SEAS ferrofluid tweeter; by distorted I acknowledge my fr in not ruler flat. I prefer the depth illusion my system generates as well as a solidly centered image. And I don't require additional hearing loss. I'm a music lover not a meter reader.
#10 | |
However in reality all tweeters have an acoustic 2nd order roll-off if they are used to go fairly low. 1st order electrical gives you some form of 3rd order alignment whilst 2nd order electrical gives some form of 4th order. It may be a line in the sand, but a fairly arbitrary one because it depends on the tweeter in case, and how and where your crossing over to midrange. Zaphs builds are interestingly detailed in the above respects. Zaph|Audio This has 1st order electrical, but the response is 2nd order L/R acoustic. The tweeter is only quasi 2nd order acoustic, it eventually rolls off 3rd order acoustic as it has to with the single series component. The most ubiquitous type tweeter used with a single cap is this : Audax TW010F1 10 mm Polymer Dome Tweeter: Madisound Speaker Store Knock-offs abound in car audio and cheap speakers with only a cap. Due to the high 3KHz Fs, one cap is basically 3rd order at around 3KHz. Arranging a speaker to have genuine 1st order acoustic c/o slopes is horrendously difficult to do in some parts of the frequency range. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 7th December 2011 at 02:33 PM. |
| Help with Tweeter Inductor value for 2nd order L/riley | mart.s | Multi-Way | 1 | 14th December 2008 03:56 AM |
| 1st order Passive Line Level Crossover + 2nd order Highpass? | alexclaber | Multi-Way | 11 | 4th January 2008 07:15 PM |
| deceptive perception ? 1st order-2nd order question | poldus | Multi-Way | 4 | 10th April 2007 11:58 PM |
| 2nd Order 2 way crossover Questions | BassAwdyO | Multi-Way | 9 | 12th February 2007 01:52 AM |
| 2nd Order Tweeter + 3rd Order Woofer = OK? | Jay | Multi-Way | 3 | 12th September 2005 12:12 PM |
| Page generated in 0.10748 seconds (80.33% PHP - 19.67% MySQL) with 10 queries |
