Old 4th December 2011, 05:44 AM   #1
Default Help which 10" woofer I chose out of these 3 SB or Alcone Or Visaton ???
Hello
I would like to ask any opinion from those people who used or heard these SB woofer in 3 way system or as a sub-woofer.
I want to use it in a 3 way system in a 75L BR enclosure.
AudioNL store
Another option I think about the Alcone AC 10 HE
Alcone AC 10 HE
These is the Visaton
Visaton - Lautsprecher und Zubehör, Loudspeakers and Accessories
Visaton produce some of my favorite drivers all do I never heard these driver
Any pro and contra welcome before I buy.
Thank you very much
Greetings Gabor
Old 4th December 2011, 06:39 AM   #2
Inductor's Avatar
Or VOLT B250.8 (???)
Last edited by Inductor; 4th December 2011 at 06:43 AM. Reason: what goes around comes around...
Old 4th December 2011, 01:34 PM   #3
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by gaborbela View Post
Hello
AudioNL store
Alcone AC 10 HE
Thank you very much
Greetings Gabor
Hi Gabor,
I would pick the Visaton driver at first hand for mains but not in a ported box as this driver is excellent in a closed box when Qtc=~0.5-0.6 and use the same driver in real subs (2 or more) where the extension below ~50 Hz can be fully be exploited when placed near walls/corners:
Pictures of modeled sub's :
b
Old 4th December 2011, 07:16 PM   #4
Inductor's Avatar
Originally Posted by bjorno View Post
Hi Gabor,
b
bjorno, if I was you I would divide that figure of the Visaton "Excursion limit +/−14 mm" by 2 so that I would use it for the (comparison) simulations you have presented above. Usually is good to work/use T/S parameter Xmax so that it gives a good standard between different manufacturers (and we don't call them layers afterwards). I know some don't like standards... or make their own. As Î said I have some doubts about what that parameter is about. And not saying your sims are not "nice" or inacurate. Again, I would say Xmax=7 mm until somebody proves me the opposite. Thanks.
http://www.bcae1.com/speaker.htm
Old 4th December 2011, 07:56 PM   #5
Speaker
Hi Inductor
Good point, I really did a mistake and you are quite right.
I've earlier compared this driver with one of my favorite drivers and found it is very similar in performance ( quarter-wave enclosures) :The 7" Wavecor-SW178WA01 for which I used Xmax = (16-6)2=5 mm and for the Visaton (25-8)2= 8.5 mm but for an unknown reason I forgot to do use x-max= 8.5 mm in my new simulations.
The limit 14 mm is IMO good to use for 1 Hz safe excursions when no protective low end HPF is present.
I will post a new simulation using both 8.5 mm and 5 mm as reference later this evening.
Thank you again!
b
Old 4th December 2011, 10:49 PM   #6
...I will post a new simulation using .. 8.5 mm ..later this evening...
Done:
b
kinda ot... 10" x 10" x 10" aluminum block/bar, does such thing exist? Mickey Pass Labs 9 15th November 2011 08:22 PM
Wanted to Buy: Pairs of 5-1/2";6-1/2";8";10" Seas Aluminum Woofers dtm1962 Swap Meet 0 15th January 2010 04:38 PM
Top opinions for a pair of SB Acoustics SB29NRX75-6 10” Woofers Jimmy154 Multi-Way 26 31st December 2009 03:17 AM
FS: 2 - SB Acoustics 10" SB29NRX75-6 Jimmy154 Swap Meet 3 10th July 2009 08:30 PM
2-way with 10" woofer crazyhub Multi-Way 46 9th May 2007 07:35 AM
Page generated in 0.10211 seconds (83.24% PHP - 16.76% MySQL) with 11 queries
