Old 1st December 2011, 03:10 AM   #1
Default Zaph BAMTM compatible with HK Avr 20 ?
Hi, I've searched posts on the BAMTM, but didn't find what I was looking for. Sorry if I missed it. Please post any links you think are helpful. I like the Zaph BAMTM, and would like to use them with my aging but viable 1995 HK AVR20 Receiver. Rated Specs are 65Wx2 @ 30A. Not sure of actual specs. If the BAMTM isn't a good choice feel free to recommend alternate bang for buck designs. I like double woofer designs, but will look at single woofer if better suited. Thanks.
Opportunity often comes masked as adversity.
Old 1st December 2011, 02:55 PM   #2
woof is offline woof  United States
The power is fine for the BAMTM, but my concern would be that the BAMTM is a 4 ohm design. I would bet that the HK is probably OK with a 4 ohm load, but check your manual to be sure. BTW, I love mine.
Old 1st December 2011, 03:21 PM   #3
HK's of the period are current monsters, hence the 30A specification,
handling the 4ohm BAMTM will be a breeze. 130W into 4ohms is a peak
current of around 10A (+/- 5A), you've plenty of juice to spare.
(the HK will only do very high currents into very low loads on pulsed
short term signals, no way will it actually do 30A RMS continuous.)
With no subs I'd recommend the vented floorstanding version.
Assuming the HK is rated 65W RMS into 8 ohms continuous its pretty
much an ideal match for driving the BAMTM within its given limits.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 3rd December 2011, 10:53 PM   #4
Thanks for the responses guys! Sreten, your comprehensive explanation is appreciated. I'm planning to use the PE enclosures for the sealed version to maintain a personal K.I.S.S. principle.
F.S. Zaph BAMTM vented floorstanding vaughn Swap Meet 6 7th May 2011 02:04 AM
Zaph bamtm inductor question bizbad Parts 2 31st August 2010 08:38 AM
HK AVR 335 Problems utjay2008 Solid State 0 21st October 2007 02:26 AM
Yet another Zaph BAMTM -- some questions Consul Multi-Way 2 30th March 2007 01:57 AM
Modding an HK AVR 2550 MatchASM Parts 6 6th February 2007 03:59 PM
Page generated in 0.07369 seconds (72.10% PHP - 27.90% MySQL) with 10 queries
