Does anyone have suggestions for 10" drivers for use in a 2 way crossing over at 1200Hz or so to a compression driver on a constant directivity horn?
I would like sealed box if possible, and a highish -3dB point is fine (say 60Hz) since I am going to use it with subs anyway. Goal is 115dB. I have ordered a pair of Acoustic Elegance TD10S which seem like the best bet and had a scout around the Parts Express and Madisound website but nothing seems appropriate. And from the look of things it seems I might be waiting a long while for the AE drivers. Thanks in advance for your thoughts. |
#4 | |
Me thinks you should have gone for the AE dipole 10.
perspective is everything |
#6 |
How about Volt 2500.5?
It does 65Hz in a 26L vented box. 95dB/1w and 8.1kg magnet rather than the 0.42kg of the Seas above. Might cost a little more though. |
#7 |
I would like to try this in a two way:
Seas Prestige A26RE4 (H1411) 10" Paper Cone: Madisound Speaker Store |
#9 |
#10 |
| Looking for phase plug ideas for horn loaded 10" and 12" drivers | Eva | Multi-Way | 10 | 11th December 2011 05:17 PM |
| kinda ot... 10" x 10" x 10" aluminum block/bar, does such thing exist? | Mickey | Pass Labs | 9 | 15th November 2011 08:22 PM |
| Single 8" or 10" Tapped Horn that can play 20-80Hz | maxjr | Subwoofers | 12 | 16th January 2011 07:25 PM |
| High Efficiency 10" Mid Suggestions | Impious | Multi-Way | 13 | 10th March 2009 08:21 AM |
| Suggestions for small (8"/10") subwoofer driver? | netgeek | Subwoofers | 17 | 22nd December 2003 06:01 PM |
| Page generated in 0.09942 seconds (78.16% PHP - 21.84% MySQL) with 10 queries |
