Hello
I have a need for a simulator program so I can chose the right woofer to my 75Liter BR enclosure. Until now I used one from these site but for some reason no longer available. Steve Ekblad's Free Audio Software and On-Line Enclosure Design I just finished my enclosure I have the mid woofer Gorlich tweeter Morel --both 91 and 92DB. I want to chose a 10" woofer close or same sensitivity and F3 around 30Hz. I attached a picture just to be clear what I'm looking for. Someone posted these program on the forum, for a couple days I tested several woofer. Unfortunately I didn't print them out....... I taught I can use it when ever I will need. Now when I finished the enclosure I can't use it. ![]() Please someone help me to find a not to complicated calculator where I can type the woofer Was, Fs, Qts, and the enclosure size (Liter). Also after I get the F3 I have to calculate the vent tube length. Many thanks for help, advise!!! Greetings Gabor |
#3 |
Hello
Thank you To have all same sensitivity that would be hard to get. You right. I want something close, for woofer 88.5db is good enough. I can use L pad to cut back from the tweeter and mid sensitivity. I just need a simple software to get the most ideal woofer. I think about the Alcone AC10 but there are several Scan Speak I would like to run a simulation before I buy something. Also I need to know the tuning frec. F3.. Thank you Greetings gabor |
#4 | |
Further, I would choose to go with 8"-ers rather than one 10" in that cabinet. The capacity of two decent 8" woofers in a BR-enclosure can be "more than enough" |
#5 |
No. Read the links and understand BSC (baffle step compensation). An 88.5dB woofer is good for around 83 to 85 dB mid /treble sensistivity. Two 88dB 8 ohm woofers in parallel will be 94dB and good for around 91dB mid / treble sensitivities, with minor attenuation for upper units. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#6 |
The hole is open for a 10" driver. 2PC 8" woofer not even come close to get F3 close to Hz30 I do not build speaker from 75L get 40Hz. That is a BS. Sorry but that is my opinion about that. If a system does go close to 30Hz I'm not interested on it. In one word I do not like to imagine the bass when I listening to music! Thanks for the advise Greetings Gabor |
#7 |
Actually I think about these woofer
first one Scanspeak Discovery 26W/8534G 10" Aluminum Cone Woofer 8 ohm: Madisound Speaker Store another ScanSpeak Revelator 26W/8861T 10" Woofer: Madisound Speaker Store these probably would be the best (I think I chose these) http://www.lautsprechershop.de/pdf/alcone/ac10he.pdf I did sim on these drivers when that stupid program was OK. Now I taught before I invest I want to run a last test and the program no longer works. I'll wait until will work again or I get help from someone. You know it is a lot of money just to go on and buy something. That is why I wanted to sim again. Thanks Greetings |
#8 | |
Hi, BS is not knowing your physics and acoustics, feel free to imagine both. Two 6.5's are equivalent to a 10", moreorless, and target sensitivity for a 3 way is 1 to 3db above one of those drivers realistically. In room F6 and F10 actually matter far more for quality. Two Scan Speak 18W8531G will work vented in 75L. They look decent enough to me tuned to 28Hz. (F3 around 35Hz, F6 around 28Hz, F10 around 23Hz.) rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 29th November 2011 at 06:48 PM. |
#9 | |
#10 |
Hello
Probably I wasn't clear enough. The hole on the enclosure face plate already cut for a 10" woofer. To talk about anything else is in wain. I have to live with what I have. Sorry about the BS! I got frustrated that stupid program was OK even last week now when I wanted to do the last simulation no longer working. I do not want to talk much about theories I just want to run some sim. on that 3 woofer. If someone want or willing to help me please more than welcome. I'm not planing to open a speaker shop. It is about one speaker. Did someone at least took a look on those drivers?? Thanks guys! Honestly. ![]() Greets Gabor |
| DSP audio filter program needed | neazoi | Software Tools | 2 | 10th January 2011 11:39 AM |
| SPICE program recommendation needed | hifimaker | Parts | 4 | 20th March 2007 11:24 AM |
| Target 3001 Version 11 / 12 Schematic, PCB and Simulator Program, who's using it?? | John Biles | Everything Else | 9 | 31st October 2005 11:27 AM |
| ASAP opinions needed...pls? | whiteSE | Solid State | 3 | 29th October 2005 10:03 PM |
| Page generated in 0.11460 seconds (87.01% PHP - 12.99% MySQL) with 11 queries |
