Hi all,
I'm building a center speaker to accompany a pair of fronts with ScanSpeak drivers. (http://www.speakerenco.nl/content/lu...s_zuil_03.html) The fronts use a D2905/99000 tweeter, 18W8546.01 midrange and 18W8545.00 woofer. Since it will lay flat (and because of the ever-present WAF, it has to suit the cabinet ) I'd like to use 2 4-6" midranges and a tweeter with a 3-4" outer diameter. I'm thinking about a MTM-alignment with the tweeter slightly above the centerline...Here comes the problem: I have no idea which drivers sound best with the ones in the fronts... |
#2 |
The alleged driver matching required for a centre is mostly myth. This might be interesting : http://www.humblehomemadehifi.com/do...Mk-II_copy.pdf rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#3 | |
very nice and interesting links There are beautiful speakers. There are projects for the DIY or you can just buy things? regards Caesar |
#4 |
Wow, beautiful driver and nice speaker!
With the current setup the center speaker is very audibly different from the fronts. The fronts sound very open, clear and slightly warm, while the center (an Eltax Something-center) sound harsh and obtrusive (i hope you catch my drift... ). In any case, you can clearly hear the difference... While this may be a rather extreme combination of different-sounding speakers, i'dd like to match them integrate them as seamlessly as possible in the sound created by the ScanSpeaks. This will actuallty be the first speaker i'll design myself... I've built a few kits before, but for this one i'dd like to do the cabinet- and crossover-design myself. For now I think I'll stick to the MTM-arrangement, since I'm quite a sucker for aesthetics. I will post some renders in a while, then I'lll explain my point further The fronts are available as drivers, drivers+cut wood and fully assembled. Instructions were clear and sufficient, and the resulting speakers sound awesome. I'dd recommend them to anyone |
#6 |
Nice, awesome links!
The reason why I want to build a center is mainly to improve the 5.1 system that is currently in place. Besides that there is a remarkable difference in soundstage between using just the fronts and the fronts+center. There isn't a fixed listening position in the room (deviation is +- 2 meters) and using the center the sound remains more constant while moving around the sweetspot. Attached are some renders of a quick mockup... Final dimensions are higly subject to change, but please feel free to point out any pitfalls you see; To me it seems better to solve them using proper cabinet design than to rely on crossover adjustments. I'm going for a MTM-design mainly because my clients (read: my dad & his wife) were much more supportive of the MTM in comparison to a Fullrange solution. Fullrange would definitely be a possibility (audio-wise) but is a lot more difficult to integrate aesthetically. To balance out the lines in the design (of the humblehomemadehifi-center for example) i'dd have to add some detailing to either the top or bottom of the speaker (depending on the placement of the ports). Since I don't want to use much 'fake' paint-decals but rather rely on a form-follows-function-approach, the detailing of the cabinet can't get any more complicated than can be accomplished using hand-guided routing, sawing and bending. And yes I know, I'm following a bit of a top-down approach |
#7 |
Well it certainly seems like its going to look nice if nothing else. Look at the MTM centre versions of the R+L MTM's in the links, including Zaph|Audio - ZA5 Speaker Designs with ZA14W08 woofer and Vifa DQ25SC16-04 tweeter rgds, sreten.
#8 |
Haha, I think I've got the 'looking nice'-part covered. Now on to the more important parts of loudspeaker design
But damn, the more I look, the more the MTM-center concept seems fundamentally flawed. There seem to be a lot of nice band-aids to correct flaws, but all of them are using concepts I'm only just beginning to understand. I do like a challenge, but also a good foundation, definitely since this will be my first full design. It does kinda seem like I'll have to get back to the drawing board ![]() The center from Zaph Audio looks really nice though, i'll do some proper reading and interpreting when it's not 1:30 AM |
#9 | |
Here are some examples: HTGuide Forum - CJD Khancenter - a RS180/RS150/RS28A Center Mozambique
Shaun Onverwacht |||||||||| DON'T PANIC |||||||||| |
#10 |
I recommend a "CW" 2.5 way or 3-way center.
using This coaxial tweeter/midrange: Speaker Exchange | KEF 8″ Q900 Coaxial Driver |
| Driver choice | cosmindaniel12 | Multi-Way | 14 | 21st October 2010 06:25 PM |
| Midrange choice: Scanspeak or Dayton? | Daveis | Multi-Way | 2 | 18th April 2007 04:12 AM |
| Matching center to Fronts to.... | squidbait | Multi-Way | 6 | 12th April 2004 06:45 AM |
| Scanspeak Center Speaker | Faberian | Multi-Way | 15 | 18th April 2003 06:17 AM |
| DIY Center speaker using ScanSpeak??? | vision | Multi-Way | 1 | 11th December 2001 03:33 AM |
| Page generated in 0.12843 seconds (81.35% PHP - 18.65% MySQL) with 11 queries |
