Hi guys,
As we know the higher frequencies are much directional than the lower ones, So why most of tweeters use a horn? Thanks |
#2 |
Hi epilot, are you saying that directionality is not a good thing?
#4 | |
The HF-directivety can be much better with a horn then a dome tweeter. I mean line array one's or with a slit 140 degree directivity horizontal. http://profesional.beyma.com/ingles/pdf/CP21F.pdf http://profesional.beyma.com/ingles/pdf/WL4.pdf The pressure is pushed though a small slit and then spreads on a large angle when coming out of that slit. Because the pressure wants to spread over the lower pressure surrounding area outside the horn. The horn loading also improves the impulse behavior. For the piston(dome) in the HF-driver is it like it is as big as the horn mouth. But it still has the same low mass. So you have a better mass drive force then a normal cone driver with the size of the horn mouth and there for also less loss. Most dome tweeters use a waveguide not a horn to give the pressure more, a direction and have better controlled directivery also above 10kHz. Like this qaulity classic scanspeak 19mm tweeeter although it is old it has all the technical solutions to do a perfect job. With its wave guide.
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet Last edited by Helmuth; 27th November 2011 at 04:54 PM. |
| Horn for dome tweeter | Hylle | Multi-Way | 21 | 22nd October 2009 01:26 PM |
| Why not a ribbon tweeter instead of a horn tweeter? | Curly Woods | Full Range | 9 | 15th July 2009 04:09 PM |
| cleaning of horn tweeter | testarossa2k | Multi-Way | 2 | 5th October 2007 05:27 PM |
| Horn tweeter | Keruskerfuerst | Multi-Way | 1 | 14th June 2007 12:01 AM |
| DIY tweeter plus horn. | tade | Multi-Way | 0 | 14th August 2005 06:34 PM |
| Page generated in 0.07419 seconds (75.34% PHP - 24.66% MySQL) with 11 queries |
