Old 25th November 2011, 03:23 PM   #1
Default Soffit Mounted Studio Montitors
I own a recording studio and my control room currently has a surround setup made up of soffit mounted Event ASP8 powered monitors. The speakers sound fairly good but the power amps keep failing. I would like to replace the Events with DIY speakers but I could use some help picking the right plan. I’m fine with passive speakers. My listening distance is 8-9’. The room it 20’x18.
I don’t want to modify my Soffits too much, so it would be good if I could make a monitor with the same front dimensions as the ASP8 (12.5” x 16’). I’m not sure if altering the dimensions of a cab but keeping the same internal volume is doable.
Because they will be soffit mounted I would like front ports. Is it possible to use a design with a rear port and move the port to the front?
I am an experienced wood worker and would like to build the best speakers I can for under $500 (each)
Sorry for the newbie questions. I would appreciate any help.
Old 26th November 2011, 11:57 AM   #2
Most likely, it is the woofer amp. According to their schematic, it is powered by 3 pieces of LM3886 in parallel.
If the woofers and tweeters are not damaged, you can continue using the Event ASP8. Disconnect the woofer power amps, the #3 LM3886, and direct the output of the Woofer Crossover to an external power amp.
AmpsLab.com
Soffit mount studio monitors whiskerbiscuit Multi-Way 9 28th May 2008 04:27 AM
Tang-Band full-ranger in a soffit-mounted system? Consul Full Range 6 6th November 2006 10:34 PM
flush mounted in wall studio monitor, any advantages??? Greggo Multi-Way 24 2nd December 2005 03:06 AM
Flush Soffit Mount Studio Monitor Mounting Magnetar Multi-Way 3 10th October 2005 09:52 PM
Soffit mounting- RyanC Multi-Way 4 18th May 2005 04:44 AM
Page generated in 0.06972 seconds (70.21% PHP - 29.79% MySQL) with 10 queries
