Old 25th November 2011, 02:59 PM   #1
Default SEAS 27 prestige series tweeters
I.e. 27tdfc, tbfc/g and on...Do someone know what is the x-mech (not x-max/x-linear) of these tweeters?
Thanks.
crazyhub
Old 25th November 2011, 03:23 PM   #2
Why would you want to know that...?
Old 25th November 2011, 03:35 PM   #3
Guess.
Old 25th November 2011, 04:02 PM   #4
One would assume its around +/-2mm, but may be more + than -,
as nothing gets in the way of it going plus, whilst minus depends
on the clearance of the coil/dome join above the magnet.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 25th November 2011, 04:07 PM   #5
because I generally like to cut tweeters very low; I run power capabilities simulations using x-max. Knowing x-mech allow me to get an idea of what could be called a "safety window".
crazyhub
Old 25th November 2011, 04:19 PM   #6
rgds, sreten.
I agree. Allmost all Scan-Speak tweeters similar to the SEAS are rated +/- 1.6mm, I'm relatively confident SEAS tweeters are on par with SS in this field regarding size and materials used in their surrounds.
crazyhub
Old 25th November 2011, 04:28 PM   #7
gornir is offline gornir  Sweden
gornir's Avatar
A better way of determing if they are capable of a low cross-over frequency is to take a look at the distortion measurements.
Here you have some links:
Mark K
Zaph|Audio
/Göran
Author of the "AudioExcite Loudspeaker Design" website
http://www.audioexcite.com
Old 25th November 2011, 04:31 PM   #8
Mark K
Zaph|Audio
/Göran
Unfortunately tweeters are never measured with crossovers in place, so it may be hard to extrapolate additional useful info from these tests.
Old 25th November 2011, 04:36 PM   #9
Mark K
Zaph|Audio
/Göran
Yes, I know these sites thanks. I also run distorsion measurements but as usually tweeters distorsions in the low-treble fr range are lower than those of mids I find it unuseful to look at them.
crazyhub
Old 25th November 2011, 10:44 PM   #10
Not so, quoting Zaph :
Selecting the crossover point is a fine balance of many issues. One of those issues is using the drivers within their lowest distortion working range. Like many rigid cone drivers, the cone breakup propagates as peaks in 3rd and 5th order harmonic distortion lower in frequency. We want to avoid or minimize those as much as possible. Through the design iterations, the crossover frequency started high and moved down until we get to a point where the woofer's upper end distortion doesn't make itself known. We have to factor in everything here, including tweeter low end power handling, natural response rolloffs, power response and crossover complexity among other things. It's no easy decision. In my opinion, 1750 Hz was the best for this system. A 27TDFC could easily work down to 1500 hz, but only at a certain output level. I favored 1750 over a lower crossover point that would place the power handling limit on the tweeter. Seas woofers handle power well and get very loud, so it's important to make sure the tweeter can keep up.
Xmech is a poor choice for choosing a tweeter c/o point, distortion is guaranteed,
Xmax is OK unless the driver has low down distortion issues, and some certainly do.
quoting Zaph again :
Vifa XT25 ($48) - Smoothest and most extended response curve in the group, and resulting CSD is excellent. Good tall order HD above 2kHz, but average 2nd order HD. Poor HD levels of all types below 2kHz, even considering the extended low end. It may have a 500 Hz Fs, but don't think about crossing it below 2kHz LR4 or 2.5kHz LR2. Off axis response curves available. Tested January 2006.
rgds, sreten.
SEAS Prestige L26RFX/P as a sub? Face Subwoofers 8 10th March 2011 03:56 PM
SEAS Prestige 2.5 way Boris_valkov Multi-Way 4 6th February 2011 05:27 AM
FS: SEAS Prestige 27TDFC (H1189) Textile Dome Tweeters CZ Eddie Swap Meet 1 27th January 2011 11:32 AM
FS: (Australia only) SEAS Prestige 27TDFC tweeters (2 pairs) tktran303 Swap Meet 0 21st June 2010 11:42 AM
SEAS Prestige 27TFFC bongolijus Swap Meet 4 14th June 2010 07:05 AM
Page generated in 0.11353 seconds (80.80% PHP - 19.20% MySQL) with 10 queries
