Old 22nd November 2011, 05:02 AM   #1
Frosteh is offline Frosteh  United States
Frosteh's Avatar
Default $1000 budget...what to build or clone?
The lowdown: I want to build a 5.2 system. I already designed and built subs, so I need two fronts, rears, and a center channel.
The budget: $1000 including MDF, drivers, and XO parts (though I may go active XO like my current speakers).
The question: I want to build the best system I can for about $1000, not including amps or finishing. I've been eying the Swan F1.1's to clone simply because they are gorgeous and I've heard them before. However I don't need that much bass in my mains. My subs will be XO'd at 80Hz, so ideally the mains are good to there or just a bit below. I'd like a MMTMM arrangement to eliminate baffle step.
Any suggestions of preexisting designs or high end setups to try and clone?
Old 22nd November 2011, 06:33 AM   #2
Frosteh's Avatar
Let's change that a bit. $1000 for just drivers, nothing else. I can bump it to $1200 if necessary.
Old 22nd November 2011, 10:24 AM   #3
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
Good capasitors are audible with good drivers you do not want to mis those in yourspeaker. And they cost about the same as a tweeter.
Troels gravesen has done a lot of building and testing I would recommend his best scanspeak design. It will blow the budget I am affraid.
It has the ingredients of a god design a speaker for sub low a high quality midrange and tweeter, and XO using quality superior-Z capacitors.
Jensen-1071
Maybe the jazzman is on your budget limit.
JAZZMAN
Audiotechnology is a nice high-ended brand a book shelf type with a very nice ribbon of swans this will be within your budget.
http://www.troelsgravesen.dk/AT-SW.htm
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 22nd November 2011, 10:43 AM   #4
You won't go too far wrong using this family of designs :
Zaph|Audio - ZA5 Speaker Designs with ZA14W08 woofer and Vifa DQ25SC16-04 tweeter
There is a MMTMM, and an interesting discussion of its properties.
If you want to attempt active, all the transfer functions are shown,
note the cleverly included notch filters done with a small capacitor
across the main bass inductor @9KHz, they will be tricky to include.
rgds, sreten.
http://www.zaphaudio.com/ZA14W08/design.html
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 22nd November 2011, 11:55 AM   #5
rvrazvan's Avatar
An geddlee/econowave?
i think this is the way to go....and you will have the extra benefits of ..high efficiency
Old 22nd November 2011, 03:16 PM   #6
woof is offline woof  United States
I built the full size Statements for my brother. They exceeded my expectations 10 fold. Including a nice veneer, I spent less than $800 for everything.
Statements
First build - have CNC, modest budget momerath Full Range 22 18th May 2012 01:30 AM
KODA clone - slightly new topology (1000 watt amp) ostripper Solid State 25 18th February 2011 10:02 AM
high efficiency speaker with a budget of us$1000,00 angeloitacare Multi-Way 21 22nd May 2008 11:23 PM
JBL Project Array 800/1000 clone inrank Multi-Way 8 11th September 2006 06:26 PM
$1000 budget for drivers. SkinnyBoy Multi-Way 5 14th January 2005 12:35 PM
Page generated in 0.07969 seconds (77.63% PHP - 22.37% MySQL) with 10 queries
