Hi All,
I have a question about the recommended correction circuit for a 17W75 dynaudio woofer. It is a 15 uf cap and 4.7 ohm resistor. Does that go in parallel with the driver? |
#2 | |
#3 |
Thanks, I think the max I can x over this driver is 2500 hz and I am using the Focal T121 tweeter so Iwas thinking a 2nd order and inverting the polarity. The tweeter with anything less than 12db per octave would be dangerous, right?
#4 | |
One question at a time. No is not dangerous if done appropriately. To test for a 1. order (after checking all the data prior to do that) you need to have a space in frequency (one or more octaves) between Fs and the crossover point, as a standard rule, doesn't mean it can't be done with less. What woofer do you have, I can't assume is a 4/8 ohm (car/home?). And there are 4 Dynaudio specs models published. 17w75 (this one to 2K5Hz max as you stated) 17w75 ext 17w75 XL 17w75 LQ esotec What conditions do you have for the drivers (specs), do you have any crossover design you are looking at yet, and location for your speaker, I suppose it's you home. Designing a complete system it's a consequence of all the data and there is no unique answer for the formulated questions you might ask. |
#5 |
What's the Fs for T121 (is it T121 or TC121?) (specs/curves?). For the Focal TC 120 it's 800/900Hz.
#6 | |
The woofer is the basic 8 ohm 17w75 (Not the Ext or other variant) I am using 2 in parallel in a home audio setup. I do not have a specific xover design, but coming up with one with input on the board. I can not find specs on the T121. I think the Fs is 1k. it is 92db eff. Hope this helps. Thanks for your help. |
#7 |
So, you plan to cross the woofer at 2500Hz, one course of action would be to use a single capacitor set to cross the tweeter at 5000Hz (between 3 and 5uF.. is it 8 ohms?) not expecting much but once you listen to it you'll have some clues to set you on the right path.
#8 |
There is this 2. order crossover for your tweeter (T121) from Focal (Reference: Plan kit 130).
C1=3.3uF L3=0.35mH R1=3R9, R2=1R2 Cabasse - Focal - diyaudio.rs I don't know the crossover frequency, without simulation, but I guess there will be a gap in frequency output (to high for the woofer?, maybe not). Place an inductor and zobel on the low pass and test. Last edited by Inductor; 23rd November 2011 at 01:11 AM. |
#9 |
Here kit dynaudio with two 17W75 parallel (long extension XL). T/S specs similar.
http://www.gattiweb.com/images/dynaudio/double_3.pdf Last edited by Inductor; 23rd November 2011 at 01:27 AM. Reason: Good luck. |
#10 |
Wow you guys are good! OK so I will draw it up and post and then test.Sweet!
| Hawksford output error correction circuit? | Jorge | Solid State | 96 | 12th December 2011 11:31 PM |
| Has anyone tried this BS correction circuit? | G | Full Range | 4 | 14th January 2008 09:11 PM |
| MLTL minus correction circuit | Shae | Full Range | 3 | 11th October 2007 12:48 PM |
| MLTL correction circuit position | Lostcause | Full Range | 7 | 24th September 2005 01:10 PM |
| Dynaudio D28AF Correction | whitney | Swap Meet | 0 | 14th February 2004 05:23 PM |
| Page generated in 0.10548 seconds (80.21% PHP - 19.79% MySQL) with 11 queries |
