Damaged rubber ring Tannoy DC6T
Old 21st November 2011, 02:22 PM   #1
Martyn DC6T is offline Martyn DC6T
Default Damaged rubber ring Tannoy DC6T
Hi folks!
I have a new set of Tannoy DC6T's which I absolutely LOVE! They are an awesome set of floor standers even with my lowly Yamaha RX-397 providing the power.
3 days ago I nearly had a heart attack when I noticed that one of the rubber rings had 'cat damage', I small rip in the top woofer. I have been in contact with Tannoy's dealer in Spain and they want 230 euros to supply me with a whole new cone! Thats a lot of money for me especially considering how small the damage is!
My question is can I in anyway repair this rip without replacing the whole woofer? I really don't want to pay out 230 + postage for such a stupidly small amount of damage. I really want to get it repaired incase it gets worse or starts to affect the sound quality.
I have attached a photo of the damage and would like your opinions. Can I repair it locally? Will it get worse? Will it affect sound quality?
Thanks in advance folks, your help would be really appreciated!
MartynClick the image to open in full size.
Old 21st November 2011, 02:52 PM   #2
rob g is offline rob g
The rubber ring is the surround.
That drive unit price you were quoted sounds very expensive indeed, have you tried contacting Tannoy directly?
Tannoy - About Us
Old 21st November 2011, 03:17 PM   #3
R.I.P.
Yes it can easily be repaired with no detriment to the driver.
If is a pvc type surround I have used a small quantity of "vinylweld",
(intended to fix rips in faux leather furniture), before to good effect.
If its more like a foam a small amount of PVA wood glue works well.
rgds, sreten.
Old 21st November 2011, 03:29 PM   #4
I second that. Try the Vinylweld first, use very sparingly.
Leather & Vinyl Weld
Old 21st November 2011, 03:38 PM   #5
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
And apply from the rear to keep the front neat.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 21st November 2011, 03:51 PM   #6
I like where this is going. Looks like you guys are gonna save me a small fortune! Which comes as a great help considering I'm gonna become a Dad on Wednesday!
I gonna have a bash at repairing it with some of this Vinylweld, I will see if Leroy Merlin sells it, they should have some.
How do I go about taking the woofer out of the chassis? There are no screws or anything, I guess its glued in ?
Martyn
Old 21st November 2011, 03:54 PM   #7
oops, as above!
Old 21st November 2011, 04:00 PM   #8
DrDyna is offline DrDyna  United States
DrDyna's Avatar
I've fixed a driver with cat damage just like that with a little rubber cement on the end of a Q-Tip, from the back side. You can't even tell.
Edit: Does that gold ring come off? It looks like the screws are hidden underneath it.
Old 21st November 2011, 04:55 PM   #9
Martyn,
Ask Tannoy how the silver ring comes off unless you can see a recess in the rim. Obviously you do not want to damage the cosmetics of the baffle.
Some speakers with no visible screw points are bolted in position with a long bolt attached to the back of the cabinet, and loosening this simply allows the driver to fall out the front. I do not think the Tannoys are like this from memory.
Damaged rubber ring Tannoy DC6THide this!Advertise here!
faraday ring shape ?(shorting ring) guitar89 Construction Tips 2 9th September 2011 10:38 AM
My Tannoy Monitor HPD 385 in Tannoy Berkeley enclosure is completed. lhgin Multi-Way 0 11th May 2011 04:18 PM
Tweeter damaged? Or worse, crossover damaged? Someone7272 Multi-Way 7 31st May 2010 09:44 PM
about the shorted ring (flux stabilizer ring) haggy Multi-Way 3 4th January 2002 03:04 AM
Copyright ©1999-2017 diyAudio
