Old 20th November 2011, 11:57 AM   #1
Deadly Sones's Avatar
Default Help identifying cap type
Hello,
I removed this cap from a Kenwood KVS-310 3 way xover. It shorted when the midrange went. Its a 10uf 100v cap that appears to be made by Hanlan? I'm not familiar with this type of cap. Need to know its type... its rather large compared to other 10uf 100v caps I've found. More importantly... where can I buy one? If someone could possibly link me to one, that would be great.
Thanks in advance.
Old 20th November 2011, 12:11 PM   #2
pdul is offline pdul  Denmark
It looks to me as a bipolar electrolytic. If it is in series with the speaker unit
you should replace it with 10uf poly cap. of some kind and if paralel just any bipolar good for 100v or more
Old 20th November 2011, 12:28 PM   #3
thank you. I'm not quite sure... I think its series? one end is connected directly to - and the other connects to a large resistor and another cap eventually going to the speaker +... not sure... hope this pic may help...
Old 20th November 2011, 12:38 PM   #4
Without having tried it myself, this looks ok for the purpose, just replace it in the other speaker too.
Old 20th November 2011, 12:45 PM   #5
Just use MKP types anyway. In series it will be a potential improvement, and in paralel it won`t make any difference. Just make shure that it is good for 100v or more, and that you do the same in both speakers.
Old 20th November 2011, 12:47 PM   #6
mjf is offline mjf  Austria
#QUOTE
looks like a bipolar electrolytic cap to me...........often used in xover.
Old 20th November 2011, 12:48 PM   #7
Farnell or any of your local component pushers can help you with the capacitors. It is very common.
Old 20th November 2011, 01:17 PM   #8
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Here, you go, in canadian funds too
Solen Electronique Inc.
Bonus; This is a 250v cap, it shouldn't pop like your electrolytic which seems to have expanded from heat far enough that the plastic wrapping snapped.
Old 20th November 2011, 01:24 PM   #9
Awesome! Thanks everyone! It was glued against a large ceramic resistor. So that was definitely the heat source. ;-)
Help identifying Package Type of Fuse for cabinet leethree Parts 7 19th September 2009 04:22 PM
Help Identifying Cap..... dmongrain Parts 13 1st June 2009 03:20 AM
What type of CAP? Gophat Car Audio 4 28th April 2008 03:14 PM
Identifying a cap... EchoWars Parts 4 27th August 2006 10:43 PM
Identifying this damn cap? cm961 Parts 6 25th June 2003 12:10 PM
Page generated in 0.09286 seconds (76.88% PHP - 23.12% MySQL) with 11 queries
