Old 19th November 2011, 01:30 PM   #1
vega65 is offline vega65  Norway
Default 414-8a alnico 8 ohm T/S ?
Have searched without success. Need the specs for calculation of a small onken enclosure.
Old 19th November 2011, 05:39 PM   #2
Inductor's Avatar
Altec 414A/416A/515B/406B Loudspeaker Spec Sheet
http://www.greatplainsaudio.com/vint...F_Speakers.pdf
Thiele/Small Parameters For Most Altec Speakers
http://www.greatplainsaudio.com/altec_thiele_small.html
Onken Calculator
Onken Calculator
Old 19th November 2011, 05:45 PM   #3
I know these, in the T/S list 414 a is missing
Old 19th November 2011, 06:09 PM   #4
Inductor's Avatar
You can measure.
Old 19th November 2011, 11:44 PM   #5
GM is offline GM  United States
GM's Avatar
Originally, ~30 Hz Fs/0.3 Qts/14 ft^3 Vas, but I've seen re-cones with much different specs, so you really need to measure yours if planning to build such an elaborate, fixed port cab.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 20th November 2011, 08:34 AM   #6
Thanks GM.
resulting in an enclosure of ca 200 liter , before rising Qts due to higher zout from amp.
Old 20th November 2011, 08:49 AM   #7
Sorry ....
Asuming alignment5,7 above.looking for a driver to fit in a smaller enclosure.ca 100l or less should be fine.
By the way GPA makes 414-8a alnico , specs promised pr Mail. The above indicates the 414 is candidate for future project.
Old 20th November 2011, 02:19 PM   #8
GM's Avatar
You're welcome!
Based on some others GPA 15" re-cones, it wouldn't surprise me if they only use the later 'B'/'Z' series which has a much lower Vas [~125-160 L of mine and others OEM units] to fit two in the 9844 studio monitors, so no problem fitting them in 100 L tuned to around/at Fs.
Anyway, please post GPA's specs.
GM
Old 20th November 2011, 02:56 PM   #9
Inductor's Avatar
You can find nice pics on the theme in some Portuguese forums (no translation) here
Sistema ONKEN (Escuta)
and some Onken made in Portugal by a russian friend named Oleg Lesnikov (12" and 15").
AudioShow 2008
hi-fi.pt
Lesnikov Acoustics
Lesnikov Acoustics pic
Old 20th November 2011, 03:06 PM   #10
Publishing T/S parameters is common practice.
It would be clever when GPA would do it also; seems to me a requirement in order to be taken 100% serious by the loudspeaker community.
Altec 414-8a vega65 Swap Meet 0 11th November 2011 04:03 AM
Altec 806A 16 ohm to trade for 806 8A (8 ohm) diaphragms nelsondog Swap Meet 0 7th April 2010 12:32 AM
FS: Coral alnico 6 inchers and Coral H-12c alnico tweeters MichaelPublic Swap Meet 2 27th June 2008 11:24 PM
Altec 414 in 'Yves TL'? fred76 Multi-Way 1 20th December 2006 05:56 AM
Altec 414 barossi Swap Meet 2 19th June 2006 08:54 PM
Page generated in 0.10202 seconds (81.60% PHP - 18.40% MySQL) with 11 queries
