Old 15th November 2011, 01:04 PM   #1
lduarte1973's Avatar
Default audax HM210Z10 8"WOOFER 99DB
anyone used these before ? what is HDA Aerogel ?
HM210Z10 - RumoH - Caps, coils and speakers
Old 15th November 2011, 03:17 PM   #2
jerome69's Avatar
Never use it.
HDA aerogel is a mixture of keyvlar and carbon fibre.
It is a high end driver from Audax. This driver is a midrange, usable in a 3 ways.
The woofer version was used in 2 ways, in very high end french loudspeaker :
L'enceinte LEEDH Psyché 2 - Voir le sujet forum .
My personal taste, i like aerogel in the bass frequency and i like them less in the midrange. I am using 2 x 6" HDA aerogel for sub in my car.
Old 15th November 2011, 03:30 PM   #3
pinkmouse's Avatar
Originally Posted by jerome69 View Post
Never use it.
Ditto here, though I'm sure I will one day.
Disagree completely. You do need to take care of the back wave though, as the cone is so light sound just comes straight back through from any reflections in the box. If you search for my name and HM100Z0 you'll find more of my tips on how to use them.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 15th November 2011, 05:44 PM   #4
The HM210Z10 is great mid driver, that should be crossed over 300Hz. If you need a woofer, the HM210CO would be another great driver build by Audax.
Old 15th November 2011, 05:45 PM   #5
jerome69's Avatar
Tip to know
I had a similar experiment with polypropylene cone, in a classic box i don't like the sound but in a very good neutral box,weighted with sand, nothing to add
Old 15th November 2011, 06:23 PM   #6
In french :
L'Aérogel est un matériaux exclusif développé par Audax. C'est un composite ultra léger, extrêmement rigide et parfaitement amorti. Il est constitué d'une matrice de gel polymère acrylique enveloppant des fibres de carbone et de kevlar.
Sorry for my answer in PM lduarte, i thaught it was paper fiber or its carbon fiber
in Aerogel.
Old 15th November 2011, 06:31 PM   #7
remerciements de la réponse Pascal
Old 15th November 2011, 09:52 PM   #8
wolf_teeth's Avatar
It's not CF.
It's glass-fibers embedded in a NASA/space-polymer gel. Sort of a high-tech poly-fiberglass blend.
Later,
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Old 16th November 2011, 02:54 AM   #9
tomtt's Avatar
Location: kansas city mo, and on occasion, around the world ...
seems to be more than one 'aerogel'
carbon.
silica.
alumina.
tin oxide.
Aerogel - Wikipedia, the free encyclopedia
Old 16th November 2011, 03:44 AM   #10
ScottG is offline ScottG  United States
It's actually a Carbon and Kevlar (small)-fiber embedded in an *acrylic* gel. (..moisture is removed from the gel and leaves a very porous paper-like foam in it's place. There is a very thin elastic "skin" on the front of the driver, but not on the back. I've no idea what the exact material of the "skin" is, but it also seems to be different from other Audax aerogel drivers.)
The pro driver diaphragm (6" and 8" driver mentioned here) is a bit different than the other versions, and I'm betting the HM100Z0 is also somewhat different as well (and still not quite like the pro driver versions).
I have the 6" pro version - perhaps the best mid I've hear in some (but not all) respects. Extremely detailed with an overall natural sound, yet slightly over-damped. The 8" pro version may not be as over-damped as the 6" - but I'd bet it's every bit as clear.
As a comparison: Seas Excel magnesium (every driver I've heard in this line that's magnesium) - clear, but not as clear. NOT natural sounding. Much more over-damped. Poorer rendition of dynamics and the subjective impression of depth is lacking (..when compared to the 6" pro aerogel mid).
The 6" pro aerogel driver is clearer than any paper driver I've ever heard (including very efficient mids with paper diaphragms).
The 8" pro was used in this design (Optimum):
http://www.groundsound.com/hh_p45.php
http://www.hobbyhifi.de/Bestellservi...vk_optimum.pdf
perspective is everything
WTB AUDAX HM21 0Z 12 8" woofer mihow2007 Swap Meet 0 21st January 2009 10:27 PM
FS: Audax HM100Z2 - 4" Mid-Woofer zener_diode Swap Meet 5 12th March 2008 07:19 PM
replacement audax 8'' woofer fin1bxn Multi-Way 7 21st December 2007 05:45 PM
FS: Audax HT210K2 8 in. woofer pair omarmipi Swap Meet 3 18th September 2006 11:27 PM
1x Audax 20cm woofer Praudio Swap Meet 0 17th September 2003 01:30 PM
Page generated in 0.11610 seconds (79.89% PHP - 20.11% MySQL) with 10 queries
