Old 15th November 2011, 10:18 AM   #1
Default 4ohm midrange with a 8ohm crossover
I have a 4 ohm midrange driver that I want to use in a 8 ohm crossover design.
also, I use a tube amplifier so I guess 8 ohm will be easier on the amp.
What is the best way for doing this ?
I remember there is a way to connect two 8 ohm drivers in parallel and get 16 ohm impedance.
Thanks.
Old 15th November 2011, 10:23 AM   #2
just another
wintermute's Avatar
connecting two 4 ohm drivers in parallel will give you nominally 2 ohms impedance, you need to connect them in series if you want 8 ohms
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
4ohm drivers with 8ohm crossover? nonsuchpro Multi-Way 16 19th September 2011 07:14 PM
8ohm speakers 4ohm tap 5u4 Tubes / Valves 1 17th April 2009 11:22 PM
Scanspeak Midwoofers: 8ohm vs 4ohm fb Multi-Way 0 11th August 2008 02:20 PM
4ohm speakers for 8ohm application? SikSS Full Range 4 15th December 2007 04:09 PM
8ohm or 4ohm? adrrad Chip Amps 5 21st October 2007 04:29 PM
Page generated in 0.09183 seconds (63.17% PHP - 36.83% MySQL) with 10 queries
