hi
i want to know what kind of power amp suits best for what type of driver? i mean i have heard tube amp sounds good for tweeters.....pls suggest me good amp kits (available on ebay or other online stores) for driving tweeters and woofers seperately. i am looking for around 75-100w power amp for woofers and around 25-40w for tweeters. thanks pranam |
#2 |
Yes. I think they sound good with woofers too. I wonder if they say that because they are often lower power? or maybe it's because the more objectionable distortions are more audible in the treble.
If you have sensitive speakers (a good thing) then you might want to avoid poor quality class AB solid state amps in particular, otherwise it's kind of hard to go wrong. |
#3 |
I find woofers sound best driven by a low output impedance amp.
This excludes valve amps but they are nice for treble. |
#4 |
#5 |
why don you go for a 2nd hand amp for your woofers ? most used units are as cheap as building a kit.
i have a arcam delta 290P as mid amp , you can buy them realy cheap if you´re in UK where are you from by the way ? |
#6 |
I'd definitely go for s/h.
As for output impedance I find the lower the better to my ears but ears may vary. The amps I use currently are rated with a damping factor of >400@1kHz. There are once with lower o/p impedance (higher DF) but they are well beyond my means although I still might be tempted if a very cheap MC2 Audio MC1250 would cross my path. The closest I have come to an 'objective' test was a friend and me used a pair of speakers one driven by one channel of one amp and the other by an identical amp which was bridged. They sounded almost identical but the bridged amp was ever so slightly more loose in the bass. And I like tight bass. |
#7 |
#8 |
i like to use the same amp for tweeters and woofers.
(the woofer one may use more output devices and a stiffer PSU). |
#9 | |
SO does solid state.
So does Class D. If it's a good amp and a good speaker design, it'll sound good Quote:
Of course that NC400 is tempting but its theoretical advantages seem wasted on a woofer and costwise, it seems like too much power for a tweeter. |
#10 |
anybody used LM7293/4 based power amp? how does it sound?
| 2way bi-amped system with digital crossover | stan | Multi-Way | 0 | 9th August 2010 03:08 AM |
| Comments on 3 way bi-amped please ? | fat_terry | Multi-Way | 11 | 18th January 2007 04:17 AM |
| Filter Questions/Suggestions for a Bi/Tri-amped System | metal | Multi-Way | 12 | 27th November 2005 11:17 PM |
| Where to place the amps in bi-amped/tri-amped | Xicarius | Everything Else | 1 | 4th August 2004 12:13 PM |
| Just bi-amped my speakers. | Jean | Multi-Way | 10 | 25th February 2003 04:29 AM |
| Page generated in 0.09763 seconds (78.39% PHP - 21.61% MySQL) with 10 queries |
