Old 9th February 2012, 11:55 PM   #31
bwaslo is offline bwaslo  United States
No, Schroeder freq is not a cutoff, it is a frequency below which the response becomes dominated by standing wave modes in a room (and so a waveguide doesn't make much sense since directivity won't be much of an advantage anymore). A horn could get you some better sensitivity, if that's your goal, but it going to have to be either in a corner and/or huge to really do much down at frequencies you might consider to be "bass".
Old 10th February 2012, 02:06 AM   #32
Bigun is offline Bigun  Canada
Bigun's Avatar
well 'huge' is all subjective.
Macondo speakers from Romy the cat
These are Tractrix horns, single driver per horn. The largest one covers the upper base frequencies and goes low enough to cross-over to a sub. I have considered this option but the effort involved looks larger than the horn... one of those projects that you regret even starting
I thought a single horn, like the Synergy, looks like a much more practical option. But it's not a good option for me in this regard unless it goes low enough to cross over to a sub (and possible be useable even without a sub) or I still need another large box. I'm not necessarily afraid of making it fairly big like the one shown in the link. There will only be one - it's a mono project.
The constant directivity is a bonus, the more important benefit is that being a single horn it will be more practical to build it, install it and move it around compared to a multi-box option.
I'm still not sure what I'm missing here, before I discard the idea of a Synergy type horn I'd like to learn a bit more.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 10th February 2012, 02:25 AM   #33
AllenB is offline AllenB  Australia
A lot of the midrange bandwidths discussed around synergy horns wouldn't seem to get the most out of a compression driver in a home situation. It's really no big deal to have a 1" CD cross below 1kHz. Especially with the narrower horns discussed here. I'd personally prefer to see good pattern control to well below 500Hz, preferring to go down to fschroeder and I'll gladly push the CD to make it all two-way.
synergy like horn, using CD rvrazvan Multi-Way 5 4th November 2011 08:28 AM
Unity/Synergy horn 454Casull Multi-Way 6 20th September 2011 05:39 AM
Synergy Horns johnB23 Full Range 0 17th June 2011 01:48 AM
Synergy - Meet the monster SunRa Multi-Way 20 10th February 2011 09:09 AM
DIY Synergy horn ideas nl Multi-Way 8 3rd September 2009 03:42 AM
Page generated in 0.06814 seconds (73.59% PHP - 26.41% MySQL) with 10 queries
