Old 13th November 2011, 02:04 PM   #1
NSX is offline NSX  United States
Default Idiot proof 2 way open baffle
I would like to put togeather a simple 2 way open baffle to put on top of two built in book shelf units. The room is about 25x25 so something with some oomph would be needed. Also a larger cone would get down to the 35-40 Hz I would like. A 325 watt sub will take it from there. Top end 20 Khz. I just dont have the skills or equipment to build a box plus the opens that I have heard are pretty good.
A Yamaha RSA1000 receiver 100 Watt x7 will drive them in a 5.1 surround system. The speakers should be of ample quality to serve as mains for audio listening only.
Any recomendations of kits or plans ?
Is this the right direction in your opinion ?
Thanks.
Old 13th November 2011, 02:52 PM   #2
Pano is offline Pano  United States
Pano's Avatar
How big a baffle? What's your budget?
Fast, fun, Inexpensive OB project
Old 13th November 2011, 03:13 PM   #3
jerome69's Avatar
Yes good direction...
What is your budget ?
Some kits at different prices. There are not a lot of kits in the world. These kits are very hard to design.
Acapella NEXTSEAS W22NY001 +
Dionysus
Sunflower [Redux] - undefinition
Some kits, full open baffle passive :
OBL11
Big passive OB project (my project)
http://www.adamhall.com/index.php?se...rnativdownload
Old 13th November 2011, 03:55 PM   #4
I was just doing some research on open baffles 2 ways and came across an article on building a 2 way that goes down to 40 hz.
The down side is that its a floor stander using a 15" emminance driver and small cone upper/tweeter. The build was actually pretty reasonable at around $400.
For some reason I cant paste the link.
I may have to go higher in Hz to 60-70 range to make it work.
A 15" mounted abouve my book case on a half a sheet of plwood will not get high marks in the WAF.
I think it would trap the back of the speaker any how.
Pehaps an 8" with a real tweeter.
PS I was considering a Klipshorn mid range horn and tweeter combo and putting them up there. Dont know how low the midrange horn goes and if the sub could fill in the gap.
http://www.quarter-wave.com/OBs/OB_Design.pdf
http://www.quarter-wave.com/OBs/OB_Design.pdfhttp://www.quarter-wave.com/OBs/OB_Design.pdf
Old 13th November 2011, 04:13 PM   #5
jerome69's Avatar
To go low in bass, open baffle needs drivers with area.
A 8" + 1" why not ? till 100Hz.
look at this : Dipole protos
If you want the baffle small, go to active.
Old 13th November 2011, 04:53 PM   #6
You need big cones and power to get "oomph". How close to the back wall will these be? Dipoles need space..........mine are about 5 feet from the back wall and only about 2 from the side walls, and I'd still like to get them out farther!
Old 13th November 2011, 08:01 PM   #7
I have 16" from the front of the bookshelf to the back wall. Height of each space is 24" and the width is 40". Past that is open space and the distance between shelves is about 6'.
Old 13th November 2011, 08:05 PM   #8
kevinkr's Avatar
I fixed the typo in the thread title...
www.kta-hifi.net
Old 13th November 2011, 08:56 PM   #9
rvsixer is offline rvsixer  United States
I'd suggest looking at other solutions, that ain't no place for OB.
Old 13th November 2011, 10:05 PM   #10
Like I said; Idiot proof
idiot proof mono push pull 6l6gc schematic wanted jasondace2b Tubes / Valves 29 13th October 2011 01:22 AM
Upwards aligned open baffle? ( pop box meets open baffle ) OllBoll Full Range 3 28th March 2011 01:00 AM
Murphy baffle radios [ open baffle ] keithpeter Full Range 10 11th September 2007 07:59 PM
what effect does baffle have on open-baffle system? kappa546 Multi-Way 6 24th January 2006 10:21 PM
Australians- what solid timbers for baffle? (open baffle loudspeaker) tktran Multi-Way 13 29th November 2004 11:09 PM
Page generated in 0.10818 seconds (80.46% PHP - 19.54% MySQL) with 10 queries
