Old 13th November 2011, 04:17 AM   #1
wolf_teeth's Avatar
Default "Trichotomy" A completed pair of 2-ways...
Utilizing the HiVi D5G and the BG Neo3PDR, I came up with these:
Box volume and sim:
Sketch of tentative construction (dimensions changed in reality to adjust for things and volumes):
Cutting of 30 degree edges:
Boring of port:
Xover inside laminated MDF base:
Needed rear port flare and place for connections, so a 'rear-wall' was added:
Damped plastic tweeter cavity:
Painted:
Finished:
Simulation and Xover schematic:
Thanks for looking!
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Old 13th November 2011, 12:32 PM   #2
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Cute speakers, was the cabinet design just aesthetics?
Old 13th November 2011, 02:01 PM   #3
jerome69's Avatar
And the sound ?
Old 13th November 2011, 02:50 PM   #4
wolf_teeth's Avatar
Default Sorta... and details on sonics...
And the sound ?
The form followed function on these. I knew the xover would have to be external, as it's too large to fit in 4.5 ltrs, which was also a goal. I wanted less than 50 Hz extension, and that's a tough row to hoe.
There a very limited number of 5" woofers that will work in a volume this small, and maybe 3 total that also have a decent midrange extension for a 2-way with enough sensitivity to keep it applicable. I knew the HiVi 5" would do it, and I wanted to try the kevlar paper over the poly since I used the Dynavox 5" in the Vijon project before. Therefore, I chose the HiVi D5G.
The BG Neo3PDR is a planar that reaches lower than most others of its size and price, and the xover needed it. Since the D5 has a cliff about 2kHz+, and the BG can go as low as 1.8kHz high order acoustic, I met the challenge.
The boxes had to have height on the baffle for both drivers, enough depth to use the 1.5" x 7" long port, while still decreasing the volume. Aside from making the BG stick out on top by itself on its own baffle, the only other way is to make it a triangular cross-section. Port could go rearward or down; up looks silly, and down was the xover, so I bored into the edge- something I'd never seen done before.
Then I had a dilemma, I didn't like the chopped in sketch for terminals, and I wanted to flare the port and place terminals- then I came up with inserting the triangular prism into a trapezoidal set of end caps, and using a 'bridge' across the shorter flats to facilitate the additional pieces the form was lacking.
It was sort of a 'sculpted' design, that was adapted everytime I had a puzzle- and you see now what it evolved into. I let the speaker tell me what it needed to be. So- that's the reason for the form.
As to the sound, I went with a little less than full BSC to keep the sensitivity up as far as I could. That's something you can sometimes get away with with a slightly higher tuning than optimal, and using a bit more boundary reinforcement. I find them to be detailed, but not overly so to become fatuiging, and a little laid back overall. Soundstage is expansive due to the shape and planar driver, but they take some juice to get going. I need about 10:30 on the dial to get them to a moderate level with my 100W/ch setup, when most require about 8-10:00. I believe they do a lot of things very right, but at the same time it's not a 3-way with the end-all resolution.
Thanks for the inquiry and comment, fellas!
Later,
Wolf
Old 13th November 2011, 03:42 PM   #5
jerome69's Avatar
Thanks, i like when small speakers sound big
Finally completed "Delta" enclosure (pics) David Gatti Multi-Way 39 26th April 2012 12:27 PM
FS: completed rythmik subs 12" & 15" Ang Swap Meet 0 8th March 2011 05:31 AM
Photos of completed Tapped horns, from "Collaborative TH" thread neddludd Subwoofers 3 3rd May 2010 11:36 PM
do matched pair (or maybe a quad) output tubes "aged" at the same rate? jarthel Tubes / Valves 3 9th June 2007 01:05 AM
4 Sale: Vintage JBL L40 Adjustable Crossover "Pair" (2 way) Minion Swap Meet 3 22nd January 2007 05:41 PM
Page generated in 0.09899 seconds (79.88% PHP - 20.12% MySQL) with 10 queries
