just had a good/bad experience with this, maybe
bad, because it felt like loosing my hearing maybe up to something 50% loss man it was awfull really exstreme good, because I found the reason removed the ribbon, and got my full hearing back in just a couple of hours anyone have knowledge about this subject ? |
#2 |
Can you be more specific about your experiences? Did your ears ring? Did you have a headache? Were you unable to hear up to a certain threshold or did you hear beating?
What was the set up? I assume a speaker system with ribbon tweeters. What did you replace them with? But to be specific, you said singular ribbon so was it just one channel? What was driving them? What source material were you using? |
#3 |
Perhaps you have a parasitic oscillation in your system that was being reproduced by the ribbon...
_-_-bear
_-_-bear http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. -- |
#4 | |
Ribbon tweeters generally use transformers in conjunction with a RC Xover network which could audibly transmit induced noise generated by dimmers or other RF sources. This low level noise would be audible even with no amplifier turned on. That said, the SPL would not be loud enough to cause tinnitus or hearing loss, or temporary threshold shift, though the noise may be quite annoying. |
#5 |
I did think of amp issues
I checked amp temperature/heatsinks as always, not hot at all this is the speaker with ribbon there is no transformer only used a resistor and small cap maybe the lack of transformer could be part of the reason I can say that this speaker sounded absolutely fantastic fore many months what have changed lately is that I have changed a lot of PC/TV stuff to wireless and maybe my close neighbours have wireless too I also thought of possible issues with with mechanical connection between speaker wire and ribbon itself with some crossover adjustments the speaker sounds fine again, without the ribbon but it really worked very good fore a long time, until lately I experienced really severe and painfull tinnitus attack yesterday when I began to loose hearing today, I took action I removed the ribbon adjusted the speaker and my hearing was ok with a few hours well, might indicate that I live in a very noise plagued environment, and that its worse than ever maybe caused by wireless transmitters, I don't know |
#7 |
yeah, it is
and its not over yet I only detected the problem and removed what made it worse the ribbon, causing some kind of back EMI into my stereo but to remove all noise in a modern home is impossible its just a matter of how much you can live with petrolium lamps is not an option, yet my future seems to be fighting high frequency noise ![]() and yes, I did have mild tinnitus before this and a hearing damage causing overly sensitive hearing but this doesn't change the facts |
#9 |
By safety consult an ear specialist.
Because here we have a real case of analysis distorsion : what do you think the average Joe would have done if suddenly he feels loosing 50% of his hearing ? He runs to the doc house. The DIY geek checks his system first...you see what I mean ? An other good reason is that you had tinnitus before. OTOH, the fact of disconnecting your ribbons and feeling better is maybe not absolutely related, except if repetitive, and then this doesn't exclude a medical cause. At best the ribbons are only the trigger. PS : what's this damned ribbon tweet ? a DIY thing ? Last edited by Radugazon; 10th November 2011 at 11:19 PM. |
#10 |
I would think the only way the speakers could be responsible would be if you were listening at extreme levels (real rock concert levels) for a considerable period of time. Last time I had a big threshold shift was after a long go-cart race in college, I've worn earplugs to anything loud since.
Your ears aren't sensitive to audiophile notions of good sound/bad sound, only spectrum and level. I'd go to an audiologist, especially if you have tinitus issues and random blockage. Don't mess around and don't assume it is related to your stereo. (Is Earl viewing, I believe his wife is in that profession.) |
| Why not a ribbon tweeter instead of a horn tweeter? | Curly Woods | Full Range | 9 | 15th July 2009 04:09 PM |
| Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate | lduarte1973 | Multi-Way | 3 | 16th June 2009 08:50 AM |
| Antenna noise filters | Spraiski | Car Audio | 4 | 12th July 2008 07:52 PM |
| New Ribbon Speaker Technology - Approach the perfect speaker? | cocolino | Planars & Exotics | 49 | 16th January 2005 10:12 PM |
| Titanium tweeter vs Ribbon tweeter | goldyrathore | Multi-Way | 14 | 17th May 2004 07:21 PM |
| Page generated in 0.10350 seconds (81.80% PHP - 18.20% MySQL) with 11 queries |
