Has someone used Supravox drivers in 2-way speakers? How about their quality in general? 215 GMF or 215-2000 + tweeter TG1 would be nice combo for high efficiency speaker.
I think they are not the cheapest ones. Supravox drive units |
#2 | |
The 215 GMF is really only suited for freq.s below 900 Hz, and better still an octave lower. (..it has surround problems a bit above 1 kHz - see Troel's site for more details.) Supravox itself spec.s this with it's horn + B&C compression driver combo for a good "two-way". The 215-2000 and TG1 are something else entirely, and a lot more expensive. The bargain in the group is the 165GMF. It still needs support somewhere below 1 kHz (and that's highly dependent on the interaction with the baffle). The 285 would likely work well with a 4th order bessel low-pass to "fill-in" these lower freq.s.. (..perhaps open baffle for the 165GMF and bass reflex with low tuning freq. for the 285 - sort of like a smaller version of Dick Olsher's Basszilla.) (..I'd look elsewhere for a tweeter if desired - likely ribbon or planar.)
perspective is everything |
#3 |
ScottG
The specs of 215 GMF seems to have changed since Troels wrote his article |
#4 |
#5 |
..they are the same, Supravox's spec.s are just wrong (..and have always been so as far as I know). Still, it's a phenomenal mid-bass driver - and *can* have excellent bass extension depending of the cabinet volume and the tuning freq..
#6 |
Hmm specs in Troels article is very different from the ones found on supravox site, this led me to assume they had changed the driver.Why give numbers so far from reality ?
fs difference is almost 20 hz ! |
#7 | |
it is different from 215 GMF ah, ok, I have never seen this http://www.troelsgravesen.dk/Supravox215GMF.htm |
#8 |
#9 | |
Not many will purchase an 8" driver designed with bass-reflex (onken-style) design with a 120 liter Vas. Despite the higher fs however, it still models nicely in a bass reflex. Of course it should be updated on the website.
| WTB: OB drivers, supravox, PHY-HP, AER etc. | ludcam | Swap Meet | 3 | 2nd December 2010 05:08 AM |
| Supravox bass drivers a good match for front horns? | Bill poster | Multi-Way | 16 | 5th October 2010 09:46 AM |
| Pair of Supravox 215 RTF 64 drivers | boudy | Swap Meet | 2 | 20th February 2009 04:22 PM |
| Supravox 215 Signature Bicone Full Range Drivers | abpea | Swap Meet | 8 | 19th August 2008 11:26 PM |
| Page generated in 0.09834 seconds (79.85% PHP - 20.15% MySQL) with 10 queries |
