Can I ask all of you who may have a valid alternative of the WE555 to a 4-way system so composed?
High: super tweeter Medium-high: Iwata horn with JBL 2441 or similar Medium-low: WE15A horn with driver ...? (I have the JBL 2482 is ok for a WE15A?) Low: Shearer type horn with 02X18 "woofers Thank you all for your answers Best regards |
#2 |
According to the Klipsch historian the K55 driver was based on the WE55. I have seen some the K55 on some WE horns. It may not be perfect but it is an option and inexpensive.
#4 |
What is the specific frequency range you want to cover?
_-_-bear
_-_-bear http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. -- |
#5 |
Imo, none of the Klipsh drivers shown here are suitable at all.
Klipsch Midrange | Critesspeakers.com
#6 |
Hi Personal,
JBL2482 (2" driver, F-Xover 300Hz) isn't compatible with WE15A (dont cut the horn & 2") ... not OK. Alternatives with JBL2482: Sato horn or WE66A (c.f.r Jean Fourcade) Quid: what's the (real) upper response "Shearer" horn? Note: for your 4-way horn system go for "actif-filter" (analog or digital). Allez, salukes & good luck Karel |
#7 |
Handicraft for Wood Horn
Based on this I'm guessing the lower freq. extension of the 555 has more to due with the 15A itself. With that in mind the JBL 2482 might be sufficient as long as you don't need extension to 7 kHz.. Here is a Chinese clone: http://www.lmaudio.net/index.aspx?&id=31 Distributor: http://www.loyaltysound.com/
perspective is everything Last edited by ScottG; 13th November 2011 at 07:51 AM. |
#8 |
Here, Î÷µçWE15A¸´¿Ì°æÓëÎ÷µçWE7395µÍÒôºÅ½Ç¸ÄÁ¼°æ - ¡º¾*µäÃúÆ÷Óë¹Å¶*Æ÷²Ä¡» - µ¨ÒÕÐù[Tubebbs]ÂÛ̳¼¯Èº ÒôÏì|½»Ò×|µç×Ó¹Ü|µ¨»ú|µ¨»úÍøÕ¾|µ¨»úÂÛ̳|µ¨»ú²ÄÁÏ|Ê ä³öÅ£|±äѹÆ÷|µçÔ´Å£|µç×è|µçÈÝ , I found a person who uses the JBL 2482 on two replicas, what do you think?
#9 | |
Certainly can't hurt to try it out..
perspective is everything |
#10 |
Hi ScottG,
I thought of using the JBL 2482 from 300Hz to 2kHz with the 15A, then Iwata horn with the JBL 2441 from 2 KHz to 7 KHz, what do you think? Thanks |
| Alternative driver choices for Changs | bschexnayder | Full Range | 4 | 10th June 2011 04:08 PM |
| a weekend at Melaudia (France) with the WE15A | Jmmlc | Multi-Way | 0 | 16th April 2010 08:29 AM |
| Parameters for turbosound driver / alternative | peterpion | Multi-Way | 0 | 9th March 2009 02:57 PM |
| Little Dot MKIII, faulty driver tube, GE5654 alternative in the UK? | markiemrboo | Tubes / Valves | 6 | 6th November 2007 11:34 PM |
| alternative to Radian 475 driver | dunderchief | Multi-Way | 2 | 25th February 2004 11:20 PM |
| Page generated in 0.10300 seconds (79.39% PHP - 20.61% MySQL) with 10 queries |
