Audiomaster crossover help please - diyAudio
Old 9th November 2011, 07:11 PM   #1
Default Audiomaster crossover help please
Earlier in the year I bought a set of Audiomaster MLS 2's (I think).
They really were in poor shape. Both tweeter coils were fried (AudaxHD100 D25), which I managed to replace & one of the Dalesford 8" drivers had also been wrecked, so I replaced both with 8" peerless drivers, but first compared the good Dalesford against a Peerless for a couple of days & they sounded close enough to my ears.
I have also recapped them.
The problem is they sound really bright.
The only way I can get them to sound good is when I put them through my media center with about -10db treble which is far from ideal as I want to run them on a different system with no tone controls.
Below is a link to a picture of the front & the back of the crossover:
Audiomaster MLS 2 Crossovers pictures by Impman71 - Photobucket
Any advice gratefully received
Colin
Old 9th November 2011, 07:27 PM   #2
Inductor's Avatar
You can test an L-pad (constant or variable) on the tweeter. If the problem is the woofer or mid band this doesn't work.
Old 9th November 2011, 07:37 PM   #3
I think the problem is more in the upper midrange on the woofer.
Old 9th November 2011, 08:10 PM   #4
Did it Himself
richie00boy's Avatar
Look up impedance correction zobel network for crossovers, putting one on the woofer may help your problem as it will help the roll-off to be more consistent.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 9th November 2011, 09:19 PM   #5
Thanks richie00boy, I found a calculator here:
Crossover Design Chart and Inductance vs. Frequency Calculator(Low-pass)
I have contacted the seller of the peerless woofers to see if he knows the le value.
Old 9th November 2011, 10:37 PM   #6
which model Peerless?
link to tweeter specs:
http://spicaspeakers.com/drivers/audax-hd100d25.pdf
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 10th November 2011, 08:06 AM   #7
Thanks for the link.
I think I may have discovered the problem but not sure how to fix it.
The Audax tweeter has a sensitivity of 89db whereas the woofer is 92db.
I know it's not "best practice" but can I put an L pad on the woofer?
The Peerless are SKO204 8". I can't find a spec sheet online so am waiting for Ebay seller to get back to me.
Thanks,
Colin
Old 10th November 2011, 08:48 PM   #8
re:'can I put an L pad on the woofer?' - no, & that wouldn't solve the problem you describe, quite the opposite.
re:'The Peerless are SKO204' - ahh, these are Peerless India drivers:
Peerless Specs
What are the values of the xover components, & do you have a schematic?
Old 10th November 2011, 10:40 PM   #9
Thanks for the link & advice. I don't have a schematic & there is no info on the web. The caps are 4.7, 8, 10 & 50uf. I think the inductors are hand wound - no markings.
Old 10th November 2011, 10:42 PM   #10
DrDyna is offline DrDyna  United States
DrDyna's Avatar
If it's too bright, I'd probably adjust the value of the resistor in the high pass, or use an L-pad on the tweeter.
Crossover for vifa 2 way setup - how can I find out what this crossover is doing? Tino Multi-Way 11 17th May 2009 04:21 AM
Audiomaster Speakers garysnooker Multi-Way 6 29th October 2008 08:41 PM
Audiomaster integrated (Valve) amp gee dee Tubes / Valves 1 13th March 2008 02:51 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 05:48 AM
Copyright 1999-2017 diyAudio
