Stereophonic Sound from a Single Loudspeaker - Page 44 - diyAudio
Old 21st June 2013, 07:27 PM   #431
Greebster's Avatar
Originally Posted by Elias View Post
Here a single speaker stereo aka soundbar (TV included )
Scandinavian Stereo Theatre 24
Projects sound not only to the front but also to the side walls to "surround you with the full beauty of music".
- Elias
Looks like some of the stuff my father made back in the day. Drivers on the corners, firing out the side and in front. At low levels (below say 95dB) sounded quite nice. Would listen/watch for hours without fatigue
Last edited by Greebster; 21st June 2013 at 07:28 PM. Reason: Only thing is I WAS the remote! something I dont get the pleasure of today ;)
Old 22nd June 2013, 05:36 PM   #432
Elias is offline Elias  Finland
Elias's Avatar
Using any cross talk cancellation method necessarily results in extremely tiny sweet spot. That is not good and is totally opposite what I'm targeting here.
I don't like small sweet spot but my requirement is stereo sound to be good everywhere in the room.
It should be obvious that this method relies on side wall reflections, so of course it is room dependent in that regard. First of all there must be two side walls, and secondly they should not be absorptive at the reflection points.
Room shape has some influence and a shoebox geometry seems to be the best.
Also the listening distance should not be too close.
Then comes the timing of direct sound vs reflections, and it is true that direct sound should be attenuated in level at high frequencies. The attenuation is not much about 5 dB I have found to be enough. Actually the way I do the filtering is I simultaneously boost the side elements to better maintain constant power response. See my home page for details about the filter.
- Elias
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 11th September 2013, 10:26 AM   #433
graaf is offline graaf  Poland
graaf's Avatar
I've been enjoying 3 flooders played through the matrix, and even the crappiest recordings got immediatelly improved and became almost pleasurable.
Can we say that - in view of the latest developments in Your system - that the SSS project is now - so to speak - abandoned/obsolete?
"high phooey and hystereo" - Yascha Heifetz
Old 23rd May 2014, 11:35 PM   #434
Elias's Avatar
Single speaker stereo is spreading all over the world !
Here in Japan, using matrix stereo. Driver is Fostex FE87
????? ?????????????????????? FOSTEX(??????) FE87?
Old 23rd May 2014, 11:41 PM   #435
Elias's Avatar
Here also from Japan. Stereophonic sound from a single loudspeaker
????????????: ????????FOSTEX-FE83En
Drivers Fostex Fe83En
Old 24th May 2014, 08:10 AM   #436
norman bates's Avatar
matrix stereo ?
Is that a summed mono center ?
Norman
Old 24th May 2014, 11:22 AM   #437
Elias's Avatar
Yes, those are matrix stereo speakers.
Notice two wires going in:
I wish to read more about those but my japanese sucks and one can forget google translator ... no use.
Old 24th May 2014, 11:25 AM   #438
Elias's Avatar
Also notice two wires going in there Matrix stereo speaker, yes
Old 24th May 2014, 05:10 PM   #439
CLS is offline CLS  Taiwan
Looking good.
But, well, it's a pity that it seems no real 'fullrange' system has been built in this principle.
Or, both of them need a lower section in a similar style for bass.
Old 24th May 2014, 09:14 PM   #440
Originally Posted by CLS View Post
Looking good.
Bass section wouldn't be worth the effort to build with matrixing -- on most recordings most of the bass would be steered to the center driver, and the outer drivers would be largely wasted. It would be best with mono bass - with 3 drivers if you like, but mono.
Encel Stereophonic M.F.B CSM 40 amplifier Bass Man Tubes / Valves 0 6th May 2011 01:06 AM
Sound transmission loss in Loudspeaker diaphragms thadman Multi-Way 10 21st August 2009 04:40 AM
Sound card for loudspeaker measurement preiter Everything Else 8 13th August 2007 01:32 AM
Bell Stereophonic 3030 help AtomiKM Tubes / Valves 2 24th September 2006 12:37 AM
Loudspeaker construction vs sound quality josefr Multi-Way 4 11th April 2003 07:24 AM
Copyright 1999-2017 diyAudio
