Stereophonic Sound from a Single Loudspeaker
Old 16th October 2012, 12:57 AM   #391
CLS is offline CLS  Taiwan
Originally Posted by norman bates View Post
Hopefully your speakers have a flat resistive impedance curve.....................
Hehe... that's part of the reason why I tried it with bending wave devices. Their impedance curves are pretty flat (compared to most ordinary drivers).
Nevertheless, I think the problem of impedance curve would not be so great if the 3 drivers (with the loads) are identical. Paired drivers on hand are all measured very very close to each other.
If multi-way is used, then the problem would be mostly in the xover, I guess.
Old 16th October 2012, 10:08 AM   #392
Elias is offline Elias  Finland
Elias's Avatar
The impedance of the drivers does not matter as the configuration is a 'star' network, which can be transformed to perhaps more familiar 'delta'
Stereophonic Sound from a Single Loudspeaker-theoreme_de_kennelly-png
- Elias
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 6th January 2013, 08:33 AM   #393
el`Ol is offline el`Ol  Germany
Any thoughts about this?
Inpedance linearization would have to be added, of course.
Old 6th January 2013, 08:56 AM   #394
alternatively (if output is symmetric)
Old 6th January 2013, 12:00 PM   #395
Elias's Avatar
I think single mono tweeter leads to quite limited stereo presentation.
- Elias
Old 6th January 2013, 12:28 PM   #396
The current version of the stereolith has a single tweeter.
If the old stereoliths worked like my second circuit the tweeters would have been mono with unsymmetric amps even then.
Old 6th January 2013, 12:55 PM   #397
Stereophony for both tweeters and woofers with unsymmetric amp.
If "more stereo" for the tweeters than for the woofers is desired tweeters have to be at (+).
Old 6th January 2013, 12:56 PM   #398
Elias's Avatar
Yes Stereolith (TM) indeed has single tweeter, but since when has it been considered as ultimate ? I don't think single tweeter is any good, not for imaging and not for spaciousness. It is very simple to try out.
Also I don't know why Stereolith is like it is, maybe for cost reasons.
Old 6th January 2013, 02:22 PM   #399
With version three one could test how much mono for the tweeters is tolerable.
Old 6th January 2013, 02:57 PM   #400
Elias's Avatar
For test purposes that may be a good idea, However I think the problem of single tweeter is not the mononess of the sound but the high spatial correlation of the single treble source which in my experience makes the source itself localisable.
I think it is better to use several tweeters (even for mono sound), or use some other methods of spatial decorrelation for example aiming the tweeters towards ceiling or side walls.
- Elias
Stereophonic Sound from a Single LoudspeakerHide this!Advertise here!
Encel Stereophonic M.F.B CSM 40 amplifier Bass Man Tubes / Valves 0 6th May 2011 12:06 AM
Sound transmission loss in Loudspeaker diaphragms thadman Multi-Way 10 21st August 2009 03:40 AM
Sound card for loudspeaker measurement preiter Everything Else 8 13th August 2007 12:32 AM
Bell Stereophonic 3030 help AtomiKM Tubes / Valves 2 23rd September 2006 11:37 PM
Loudspeaker construction vs sound quality josefr Multi-Way 4 11th April 2003 06:24 AM
